It seems that I have inadvertently put the cat amongst the pigeons with my little project.
Dave is absolutely correct in saying that a basic washing machine seal would fail under the lateral forces and it was silly of me to title the seal in this misleading way.
The seal is actually a double lip oil seal and made from metal and nitrile rubber, it is also reinforced with a metal garter spring that maintains a constant pressure on the copper tube
On the drawing I have also reinforced the entire seal by encapsulating it within a metal frame.
Mike: The idea is to sell as many plans as possible, the problem with designing is making the subject attractive to prospective builders whilst keeping it easy for the less experienced to build. Thor will be a challenging build but certainly well within the realms of the average model builder both in experience and equipment.
Trevor: The initial design was drawn up with 180deg thrusters but I decided to go the 'whole hog' and set myself the challenge of designing a 360deg thruster system that could be built from easily available materials.
Dave: There will be a need for speed controllers for both the thrusters and motors, all within the four channel rule, for which I am going to ask for your guidance (when I know what the current draw will be)
