Hi Bob,
Thanks for the suggestions but 4 foot will be plenty big enough, and more significantly heavy enough. If it was eight feet long it would need a mast around 8 ft 6 inches high which is just not practical. We already have a 6 foot 6 inch long sail box for Elizabeth's Marblehead yachts and that only just fits in the car.
Shemarah has progressed a bit further over the last couple of weeks. I have made the 3 long 'whip' aerials which fit on the wheel house roof. They are each mounted on a tripod arrangement which is difficult to see in detail on the photos I have so I have had to improvise. Here is the tripod base made from brass tube and strip.
It was quite difficult to solder together so, as usual I had to improvise a little fixture to hold the bits in the right relative position while soldering.
The aerials themselves were made from some more plastic covered stranded fishing trace, painted white. However the paint has not bonded very well and I think I will have to rough up the plastic covering a bit to give it better adhesion. However the aerials look pretty good. I have yet to add the connecting leads and the black box that attaches to the railings at the bottom of each unit.
The next job was the lockers which fit under the rear wheelhouse platforms. They are simple styrene boxes with a simulated lid and latch.
Here's one of the crew members admiring the finished article. As usual they are retained on the deck with a couple of 1/32 brass pins for the moment.
The inside of the wheelhouse has been finished with the last couple of display screens added and the crew glued into position. The real wheelhouse looks more cluttered but since you cant see inside the model very well it will do, at least for now.
I have also finally fixed in place the electrical connector for the wiring to the wheelhouse light, radar and speaker. It was a bit fiddly getting it in the right place. I was expecting to have to put a couple of guide pins and tubes in each half to locate them when the wheelhouse is fitted but the coaming on the deck works fine and its just a matter of pushing the wheelhouse down on to the connector. It take a bit of wiggling to free it but its not too difficult. It's certainly easier than trying to hold the wheel house up while fitting the connector on the end of a flying lead.
Finally I have fitted the two drain pipes which run down on either side of the wheelhouse.
I am getting near the end now, only about half a dozen minor jobs to do, although there will probably be a few extra ones I have forgotten.
Gareth
