Hello there
Due to my job situation I have stared to build some of the designs from plans the magazine (as I have the time for it) I just finalized the skimmer (Glynn Guest design) I start up with 2 coats of Glittfix from Graupner with a rubdown between with 400g paper ( it can be replaced with talcum / baby-powder mixed with dope). Any deep defects gets some light sander filler for wood and a rub down with 400g paper. Then I coat it with tissue and dope like a model plane. It gets a rub down with 400g paper and 2 more coats of 50/50 dope and thinner with a rub down 400-600g paper in between and in the end with 600-800g paper.
Then a spray of sander for cars and a rubdown with 800-1000g paper a layer more if it’s needed. Then a primer rub down with 1200g and the the topcoat 2-3 layers with at light rub down in between. In the end it gets some layers of clear coat to seal the surface.
But hey what is the purpose of the model, to be a display 110% nice and perfect or is it for fun at the pond ? (I forgot to seal the internals of the Skimmer and it doesn’t have that perfect figure any more after a spray of water)
Br
Carsten
Denmark
