Thanks Dave for the link, that model (Guardsman) is still with me.
Charles, looking back at the plan and my build the prop shaft and the angle were as the plan. The difference with mine was the length of the coupling as against the plan. This obviously influenced the positioning of the motor. Mine was a plan size model.
As previous, I still have the model and it's in good condition, stored in the shed, awaiting a small modification to the electrics. Component Shop sells a smaller car type fuse holder and toggle switch. I've recently received these, as the current larger type fuse holder is a squeeze to fit in.
My only comments about the design are firstly, the positioning of the navigation lights. The full sized vessel, Enterprise, which the model is based on, the navigation lights were located on the side of the cabin above the door. Vic's plan shows them mounted on the top of the cabin. With my build it was too late to change them after they had been fitted. In Model Boats magazine, September 2004, is a large steam powered version of Guardsman and the builder has worked to the full sized vessel's positioning of these lights. I've attached a couple of photographs.
The second comment, is the rudder linkage, the way it's shown on the plan would never work. It needed to be modified by cutting away the balsa blocks under the deck. To coin the saying – "It was like wallpapering the hall, through the letter box". Shouldn't be problem for your size of model and type of construction.
I wish you every success with what is a super little model and it's always a pleasure to take this one to the lake.
