Prototype build of ELLIE
Viewing 25 posts - 1,251 through 1,275 (of 1,441 total)
  • #49621
      sad
        Talking of thinking a bit harder, Colin…
        What does….."it's all your faults" mean?
          It means that its all your joint faults for mixing up the Ellie and Brutus threads….
            Should we all stand in the corner at once or take it in turns over the next couple of days? wink
            #49629
            Dave_P
              @dave_p
              Or the naughty step cheeky
              #49631
                As far as I am aware, I have never posted in the wrong thread, except to reply to a members post
                Diede van Abs
                  @diedevanabs87670
                  Nice Colin, blaming us for you having legacy forum software wink
                  #49719
                    Video of Ellie at Lyme Park
                      Bob. Having perused the videos, Ellie goes quite well, considering its not supposed to be a fast boat! however it appears to be either a bit nose heavy or wants better spray rails, or at least SOME spray rails if not fitted.
                      Sl-Mo 2 has the issue of the sponsons; the supporting tubes are in the water and the drag is obviously substantial. It does not look like to me that the sponsons are required?? unless of course it is just not going fast enough yet. Sponson supports of the "bent " variety…flat ones mounted on the hull top and bending down to attach to the top of the floats would do.. OR even better, make the floats out of blue foam. I would simply take them off for a test.
                      Slo-mo looks great though, and love the steering driver, very effective! Who`s that saying slo-mo is aptly named??? did you clip his ear?? Ashley
                      Diede van Abs
                        @diedevanabs87670
                        Ashley, I think Ellie is a bit overpowered, she should plod along at a displacement-type of speed instead of the (semi-)planing speeds she is capable of reaching now.
                        That would negate the need for spray rails, or at least reduce it to only needing very small spray deflectors at the bow.
                        I also think Slo-mo should go about without the sponsons, or have waay more power, or both laugh
                        The steering driver, and tail fin, are indeed nice touches.
                        Edited By Diede van Abs on 17/06/2014 10:38:58
                        #49760
                          Diede
                          When we built Ellie, the brushless motor option was a mere pipe dream!
                          But we did mention it would be nice to have a Wolf in Sheep's clothing!
                          Now we've got one!
                          We can creep round with rigorous mortis or charge about like a wild thing…..perfect situation
                          It's not like you to ask us to slow down!
                          Diede van Abs
                            @diedevanabs87670
                            Ah, Bob… Now we are talking!
                            Ellie was originally designed for "recreational speeds" aka plodding along with a happy mom and kids sunbathing on the deck, and dad nipping (non alcoholic of course…) cocktails behind the wheel. So unless you take measures – such as the mentioned spray rails – the boat will not quite like higher speeds. You can see that in your bow wave, and the fact that your deck got so wet.
                            Soooo…..
                            Either adjust your engine to the design of the boat, or make it a Wolf in Sheeps clothing and add spray rails so mom and kids stay dry on Dad's Mad Dashes!
                            I must confes rather seeing spray rails added than a tame motor, indeed
                            #49765
                              Hi Diede
                              Fancy you knowing all these deliberately misleading old English sayings?
                              "A Wolf in Sheeps clothing"……. "Gobsmacked"……. "A Buttie short of a picnic!" and many others
                              Why don't you tell us about yourself?….Your boats etc
                              We are a nosie lot at times!
                              Diede van Abs
                                @diedevanabs87670
                                Hi Bob,
                                I don't know many of the old English sayings, but the Wolf in Sheeps clothing is the same as we have here in Holland…
                                I could tell something about myself, and my boats, but that would only add extra chaos to this thread so I won't do it (here) lest Colin gets upset again.wink
                                There are already two boats of mine on this forum: My pocket-sized Tamar-class EeZeBilt 50+, and the EeZeBilt 50+ Sea Princess I am currently building. I will add more in the future, probably smiley
                                #49778
                                  OK, Diede
                                  At the moment I`m having another go at installing two motors in SloMo
                                  But!…..Still the 2nd motor will not run!
                                  Going to do some swapping about now, to eliminate the ESC possible problem….etc
                                    Test engineer at the pond to Drawing Office chappie
                                    Ellie and SloMo sail very nicely, as designed, but holes are required in formers to allow surplus water to be easily extracted from sump area
                                      Tea Lady to apprentice engineer
                                      Drain holes were deemed as not required as there shouldn't be any water in the boat.
                                      Chief Engineer suggests that you do one of the following:
                                      1/ To prevent water ingress by fitting glass in all of the windows and stop up any holes.
                                      2/ To prevent splashing by replacing high speed engine with design approved unit
                                      3/ To eliminate excessive splash by relinquishing control to a more experienced operator.
                                      Tea Lady says just turn it upside down.
                                      wink
                                      #49905
                                        Thank you, Tea Lady
                                        Just thought of a method of making the holes in the bulk heads!
                                        A really brill idea…..Worthy of a Eureka Moment entry!
                                        A length of 3mm wire with a pointed end and the last inch, bent through 90 degrees
                                        Then heat up the bent end and burn a hole through the bulkhead!
                                        Problem solved!
                                        I don't know how I do it for the money?
                                          I don't know how you do it either.nerd
                                            You know?….You`ve got to hand it to Paul!
                                            He`s good!…..Why did he omit the through holes in the bulkheads?
                                            It wasn`t an oversight at all!………The sections with a leak source……..Fill up first!…….Brilliant!
                                            Yep!…..Sure enough……Front section full of water…..So there`s no need to blame the propshaft is there?
                                            "Turn it over"….He said
                                            So I did……Sure enough!….There was a crack under the combing!…..Just where the spray hammers on the hull!
                                            That`s the kind of service one gets, from the Thomason Plans Dept!
                                              This may be why I suggested spray rails to keep the spray off the deck. However cracks are a good source of leaking…
                                              Now and again if it is easy I put some raised ribs in on the bottom of the boat to contain any water that comes up the propshaft so it does not slop or run everywhere. not many of my boats leak thro the propshaft, but the Nelson is a bit bad despite the usual nylon washers and tight adjustment, may be because the entire shaft run is below the waterline. All the inside was painted with resin so it is not an issue in any case.
                                                Just to let you know that The Vintage Model Boat Co exchanged the faulty ESC that was the cause of all the early motor aggro…..Quite willingly, no problem
                                                Credit due where credits due, chaps
                                                  Just noticed that this thread is over 50,000 views!
                                                  That must mean, that members of the forum are building the model?
                                                  We would appreciate a few photos and any feedback please?
                                                  Bob and Paul
                                                  #57619
                                                  Andy C
                                                    @andyc56856
                                                    Hi Bob
                                                    Once I am finished with my Triton build Ellie hull is next. I will probably do sea spray instead of Ellie, but the hull parts of this thread will be of great help.
                                                    Dave, if you pop by, I have sent a PM regarding your build of sea spray. I will start a new build thread once I am ready.
                                                    Cheers
                                                    Andy
                                                    #57708
                                                      Andy
                                                      PM sent. We've been away and only just got back today.
