Prototype build of ELLIE
Viewing 25 posts - 1,151 through 1,175 (of 1,441 total)
  • #47885
      where no pond is big enough to go flat out!
      You could fit one of these:
        You win yes
        John Lennon was influenced by Stanley Unwin when he wrote the book A Spaniard in the works, Lennon also wrote the song Working Class Hero.
          Humble shop floor worker to the Technical chappie upstairs
          Now that the frivolities are growing on you….Like a nasty rash, we need a calculated guess on where to put them!
          Ahem
          They are 330mm long x 40mm wide and have a centreline span of 400mm
          I think, touching the water slightly aft…….would be the way to go?
            Sounds good to me
            #47975
              Had a few members asking about work in progress etc
              Got to admit, I am slowing down lately, as the three projects are nearing completion
              SloMo is being worked on at the moment. Fitting the outriggers for stability and general appearance
              The outriggers are neatly fitted and will look the bizz when they are riveted and glossed over
              General view of the Three Graces
              #47978
                Hi Bob
                The boats look very good lined up together, I have been messing about with some underwater wings for Brutus to provide extra lift for the midsection of the hull.
                  Thank you, Paul
                  I would have thought that two brushless motors would have kept the nose up?
                  We'll soon find out!
                    Real progress at last!
                    Fitting the prop shafts …….an important stage of the build
                    Note the accurate method of alignment, based on the keel for location, a similar block is fitted inside too
                    The distance between the rudders and props looks excessive, but can easily be reduced
                    #48096
                      Hi SloMo fans………Work in progress again
                      Still working on the sponsons
                      #48106
                        Absolutely riveting………………..wink
                        #48109
                        Gareth Jones
                          @garethjones79649
                          Bob,
                          Do you expect the struts that attach the sponsons to be below the water level or above it? If they are above the water they may not make much difference to the top speed but they look very draggy to me. If they end up under the water I suspect they will generate a lot of drag. Could you not flatten the tubes to make them more of an aerofoil shape? It would look much better if nothing else. (and you thought Ariel's top secret keel looked bad!)
                          Gareth
                          Edited By Gareth Jones on 07/04/2014 12:54:55
                          #48113
                            Hello Gareth
                            The tubes are supposed to be above the waterline, they haven't any washers fitted at the moment and will lift up another 10 mm
                            I could also redrill the holes if need be
                            Thanks for the idea though
                              For Ashley and fans
                              In case you are wondering…..SloMo is progressing slowly
                              Motors, props and ESC's are installed….Sponsons looking nice…..Working on rudder mech at the moment and the driver animation
                              Still lots of bits that need to be done before even thinking about sailing!
                              John O’C
                                @johnoc
                                Hi Guys
                                As a "Newby", no not from Newby Bridge but Cheshire, I have been reading this merry tale for the last couple of days and am now wondering: what happened to Ellie and her plans?
                                We have been visiting the broads hire boats since 1966 hence my interest. Broadwave 3 was our first from Coltishall.
                                John
                                #48376
                                  Hello John
                                  Ellie and her plans are doing well and are available from my just giving page **LINK**
                                  If you look out for next months issue of the worlds best selling model boat magazine you will find a small article explaining how downloadable designs work.
                                    Hello Paul
                                    I've been trying to find my quick access post for Ellie, but can't find it at the moment
                                    We are at BYC at the moment
                                      I was just looking at this the other day after we were mulling over a jet powered bluebird and couldnt help thinking the sponsons would look good at the front instead of the rear…
                                      Assuming the front end lifts under the ginormous power of the b/less motors, then the sponsons would also lift off the water and thus the drag would diminish…?
                                        Hi Ash
                                        Sorry to say that the hull is the wrong shape for the sponsons to be fitted at the front as they would just dig in during turns and flip the boat over.
                                          The Paul and Bob combo, welcome another Ellie builder to our ranks
                                          All the best, John O'Connell
                                          Please post a few build pictures?
                                          I notice Ellie will appear in May's edition too……Such a well balanced pleasing design?
                                            Never mind. only a thought. Ashley
                                            #48493
                                              Just in case you think that SloMo 2 is not progressing….A few pictures
                                              Finished the Sponsons, installed the electrickery, added a few letters, vents, more varnish etc…….Like it?
                                              What`s that?……Have I tried the motors?……..Errrrr……No not yet!….Couldn`t face any motor aggro, till I`ve had my Weetabix!
                                              I`m hoping that Paul can find space on his stand at Haydock for SloMo?……Thor and Ellie
                                              #48501
                                                There will always be room for your boats on the stand at Haydock and if you get some photos of them in the water they will be included in the giveaway flyers.
                                                  Congratulations Paul
                                                  Just seen your article in the June 2014 issue of ModelBoats magazine
                                                  Describing your method of downloading CAD drawn model boat plans using the PDF system
                                                    Thank you Bob
                                                    It was very kind of Paul Freshney to print the article and the additional comments in 360 compass (page 6)
                                                    Coverage in the magaziene will bring my designs to a larger audience which will hopefully translate into more donations to the charities.
                                                      Hello Paul
                                                      I'm almost ashamed to ask you this, but what is……Compass 360?
