Producing square cuts & cutting to uniform and accurate length
Home Forums Beginners Producing square cuts & cutting to uniform and accurate length
Viewing 8 posts - 26 through 33 (of 33 total)
  • #19642
    Len Ochiltree
      @lenochiltree67043
      Hi Guys,
      It is a Powercraft bought from Aldi’s.
      Len,not on the straight and narrow!
        Hi Len
        I bought one as well and I cant get the dam thing to cut straight and now I have parted with my big band saw I need the thing to work.
          For straight cutting, you need a deepish  (12mm )  fresh coarse blade and a suitable side guide. The blade guides should be very close to the blade on either side and the minimum amount of blade exposed.
          My bandsaw is the old Burgess type and can cut 8`-0″ planks of 3mm x 10mm with ease
          Can you describe how your bandsaws behave on straightline cutting?
            Mine wanders all over the place and its set up correctly with the throat reduced to almost the top of the work piece.
            The blades on these machines are only 6mm deep.
              Hello PAUL
              My bandsaw will still cut dead straight even with a 6mm blade…btw
              Here`s my setup  for straight cutting………………….Bob
              Edited By Bob Abell on 23/03/2009 16:28:00
              #19655
              Rick Fryer
                @rickfryer11539
                My Proops cheapo wood-chopper arrived today and works like a dream. Spent a happy hour reducing three feet obechi strips to 180mm deck planks – perfect cut every time, and a simple jig means they are all spot on!
                Rick
                #19656
                  Glad it worked Rick!
                  Ducky
                    @ducky
                    Thats better Colin !! can read the text now.
                    “Aziz” sailed well on her first outing didn’t she Bob,your comments were very much appreciated and praise indeed from a master Builder, and the photo’s you took were superb as usual.
                    Micro Magic out the next good weather we get at Etherow.
                    Ducky
                    Edited By Ducky on 24/03/2009 09:05:52
                    Edited By Ducky on 24/03/2009 09:07:41
