Unlike my Dutch Courage, my new Sir Lancelot has plenty of sheets of wood for things like the decks, bulwark supports & cappings, wheelhouse, lockers etc etc – which I was fully aware of before buying the kit.
Of course, these parts need to be sanded smooth before assembly, but my question is, should they be sealed with sanding sealer (or something else?) before or after assembly (for those areas that should NOT look like wood)? I can imagine that sealing & sanding some of the cut-out parts before assembly will allow a better finish to be achieved (for example, the bulkead panels that fit either side of the front gun support between the main & forecastle decks, and the bulwark supports).
The only parts requiring sealing on the Dutch Courage are the dowels used for the mast & bollards, so all very straightforward.
Thanks guys.
