If you have some deck plans and the source of the plans is based in Cad You can get pretty close with photos of the underwater as well.
I recently had to build a 3d model of the Super yacht "MY Elements" and had no plans as such but I found deck layout plans of good quality that were from a booking site and by setting those up in a 3d modelling program and fitting the surface to the edges you can get close, its the rise of floor and stern skeg areas that require the photos most of the time.
Here is an example.
https://camperandnicholsons.com/luxury-motor-yacht-for-sale/elements-yachtley-shipyard-turkey-2019
This is where the plans were obtained from.
And after setting up the plans at the correct heights and scales the result was this, its close ,not %100 but good enough for the use I needed.
I realize this involves 3d modelling but if you can do that then it is more possible.
setup process looks like this
The red stations are the derived ones from the plans outlines. which then gets surfaced into this
The partially finished result is this..
Edited By Richard H Dunn on 24/05/2021 04:44:39
