Bob. I fiddled with the ballast a bit and the angle of the `planes when on the pond the last time.. I have swapped the fronts to the rear and made larger fronts now. I have ALSO cut some strips of lead bent so that i can place them on the rib to affect the trim very easily.
One would think that if the sub was balanced and the planes were set at the same angle it would sink on a level, eh? It didnt quite seem to work. HOWEVER. I have just thought that for that to be the case the planes should be the same size front and rear…hmmm..
I may take some tin snips along next time to cut the fronts down to be the same size as the rear in case another 2 hrs fiddling doesnt get it right. Thinking about that statement, I may actually do that before setting off. It also don`t help that there is a sticky out sonar dome on the front, and there is a bit of a bow shape just underneath causing who knows what hydrodynamic changes as it gozunda.
The other thing is, if it was in a swimming pool, it would possibly work reasonably well, but at the pond, one has wind,waves,ducks, weed and sticks to contend with (see the 4th picture, there is a twig hanging off the front). the white mast has to go as well. Black it is, or at least dark grey.
Enough paragraphs, bob?? Ash
60.. i have just realised the sub day is tomorrow and I am already out. But thanks for the mention anyway. Dash it all.
