Model boat Robbie pt.15
Home Forums Beginners Model boat Robbie pt.15
  • #14561
    mick
      @mick
      i have just got a pt 15 robbie  i wondered if anybody had had one just want to know
      what  motor or motors to use the instructions say a navy compack  and 6 to 9.6v  battery
      just  wondered what any of the other members thought or should i double motor and
      shaft it ? the plans are in german and i have no manual on the build
      DickyD
        @dickyd
        I didnt use the navy compact in mine as it is more often than not noisy.
        What I have in mine is as follows:
        Two rudders as supplied
        230mm propshaft with oiler tube and fine pitch 35mm 2 blade prop
        I used a Deans Marine Kestrel 5 Motor. (Oh so quiet)
        Overlander 50amp speed controller Discharge: 50A forward/20A reverse. Plug in and go, no set up needed.
        Tornado TRC4300 9.6v Sub C Nimh battery  which I positioned crosswise about a third of the way forward  from the transom.
        I get about  45 mins run time.
        http://i124.photobucket.com/albums/p8/DickyD_photos/DSCF0221.jpg
        http://i124.photobucket.com/albums/p8/DickyD_photos/06_editedMedium.jpg
        #14703
        mick
          @mick
          hiya  dickyd
            is your kestral water cooled ?  and where your instructions in english or german/ AND IS
          that a speaker in the front for a foghorn ?is the prop brass or plastic thanks for your input
               mick  it looks impressive on the plane and were did you get your speed controller from
          never heard of the overlander  e s c ?
          #14704
          DickyD
            @dickyd
            Hi Mick
            Kestral is watercooled
            Instructions were in several languages in one book
            Speaker for JJC sound system
            Prop plastic
            Speed controller Overlander 50amp forward 20amp reverse no setting up, just plug in and go, from
            A Model World. They do a good price on it. I have 6 of them, no problems.
            http://www.amodelworld.co.uk/
            http://i124.photobucket.com/albums/p8/DickyD_photos/Overlander50Awaterproofspc.jpg
            #14710
            John W E
              @johnwe
              hello there Mick
              regarding the instruction book for the PT15, what our Dicky forgot to mention is there are one or two of us who really struggled with this instruction book which THEY SAY is in English  and, to be honest with you, the Plan was more help than the instruction book.
               I am not, what you would really call, a Kit modeller – but, I was bought the kit as a present by the better half – along with all of the kitncaboodle – the motor which is actually recommended for the kit along with all the sound units and bits and pieces – to start off with the motor that is suggested is the one with the gear box and as Dicky mentions you can hear the thing run from 4 mile away!  it is so noisy.
              The sound effects from Robbe – the horn sound – when I was testing it out – my wife thought I was strangling one of our pet cats.   Then there was the engine noise – a series of click, click clicks, and that my friend is a diesel engine   –  not very impressed.
              As far as building the model is concerned, I quite enjoyed it to a point and I would think anyone who does do kits seriously – it will quite easily turn into a lovely model.  Hey and before our Dicky says anything – Yes……..mine is sitting in the loft….its sulking….cos it just needs its guns painting & not to mention its sea trials.
              aye, John e
              #14718
              mick
                @mick
                hiya john
                i was given the kit myself i usually  build my own models the water cooling bit is new to me
                 dicky d said the kestal motor was water cooled on deans marine site it doesnt  mention
                a cooling coil or do i have to buy one separate  i have heard the horn of the robbe foghorn and i
                agree with you its terrible sounding  the speed controller he said to use looks the same as one on
                ebay at half the cost?  i have not bought the motor or e s c  yet i just wanted feedback thanks lads
                have you put any figures on yet as i like to think it is not finished til then just my opinion i was going to
                modify some 1/35  airfix eight army multipose figures to or us multipose figures decide which are best
                well thanks lads you are a great help just hope i can do it justice like you lads
                  mick
                #14719
                DickyD
                  @dickyd
                  Figures are on all of mine, see photo above. Modified toy soldiers from Toys-R-Us
                  Deans reckon their motor doesn’t need cooling, but it does get hot after a while and it is easier to put the watercooling in now as appose to later.
                  Water cooling coil for 500/600 motors and intake and outlet and silicone tube from.
                  http://www.cornwallmodelboats.co.uk/acatalog/water_cooling.html
                  http://i124.photobucket.com/albums/p8/DickyD_photos/3324_0.jpg
                  http://i124.photobucket.com/albums/p8/DickyD_photos/1428_sml.jpg
                  #14739
                  mick
                    @mick
                    hiya  dicky d
                    thanks for the info i  found your model on the other site very good build giude very helpful
                    i can get the bits up here in southport but thanks for the
                    info redbank models of blackpool have a online shop and  scale models of skemersdale
                    have a good selections mick
                    #14741
                    DickyD
                      @dickyd
                      Hi Mick
                      I use Redbank Models a lot and find Gary very helpful and efficient.
                      Having said that Cornwall Model Boats are also very good.
                      Good luck with your build, if you need any help just shout.
                      #1646
                      mick
                        @mick
                        Any suggestions for power train?
