Hull finishes
Hull finishes
Home Forums Beginners Hull finishes
  • #43102
    Brian Muir
      @brianmuir84327
      I have fitted the hull panels (and due to bodged frame lining up) they have some small gaps at the joins.
      How to seal off the hull and provide a smooth surface for painting? Forum suggestions are epoxy, thinned wood filler or fibre glass resin?
      Any recommendations please….
      Brian Muir
        @brianmuir84327
        #43105
          Hello Brian
          Use P38 Filler from Halfords……Perfect for this job!
          Brian Muir
            @brianmuir84327
            Thanks Bob, is this just for the gaps, or can it be used to cover the whole hull? Do I need to cover the ply hull panels, or will a primer and several coats of paint do the job?
            #43124
              Hello Brian
              This might help you out
              All the best
              Brian Muir
                @brianmuir84327
                Thanks Paul, excellent info, but will I ever have the patience to follow that process…. I'll just have to try
                Cheers, B
                #43129
                  Hello Brian
                  Glad you liked it.
                  Following the process is self fulfilling as the more you do …the better the finish.
                  LARRY WHETTON
                    @larrywhetton68737
                    Hello Brian,
                    Had look at your build problem ,
                    Is to late to go back to bulk head line up..?.. and is the deck fixed down …?…
                    laying down keel and frames have let you down ,
                    if the deck as not been fixed you could try and ease of hull ply and try insert shims or lay second bulk head , the build is quite fair , so if you use the filler method go easy with the sander , you might make your ply skin a little thin, i allways give my hull inside a coat of F/G resin, makes for a strong hull, hope this helps cheers Larry..
                    #43194
                    Brian Muir
                      @brianmuir84327
                      Thanks Larry, as this is my "rough" prototype to work out these problems, I'm not going to go back that far. I ahve used wood filler ( which I had in the shed) and filled gaps and built up some depressions.
                      I then sanded the hull and applied a primer, anded and primed again, then I have applied 3 coats of gloss type paint.
                      I tried the hull in a wheelbarrow full of water and it stayed dry inside for the 30 mins it was in there.
