hull cover for Ariel
Home Forums Sailing Models hull cover for Ariel
  • #9649
    hutch
      @hutch73959
      using a nylon stocking on the hull
      hutch
        @hutch73959
        Hi Guys
        I used a nylon stocking as a cover for my two Jenny's that I built approx 30 years ago cannot remember what I used to seal the stocking any ideas?
        Cheers,
        Hutch
        Edited By b hutch hutchinson on 27/12/2017 07:04:39
        #74660
          Hutch,
          You probably used something like sanding sealer or dope back then.and these are still workable options.
          Modern alternatives would include something like Z Poxy finishing resin or Deluxe Materials Ezecote which is an acrylic water clean up resin. Both are used successfully by members on here.
          hutch
            @hutch73959
            HI Colin
            Thank for that I will look into what would be the best down here in Adelaide, South Australia.
            Cheers
            Hutch
            #74677
              Nothing wrong with traditional methods. My recently completed fishery cruiser had the balsa and ply hull finished with gumstrip paper and shellac with automotive paints over the top. An authentic organic hull which should last as long as anything else.
              Edited By Colin Bishop on 27/12/2017 22:53:42
              #74681
              hutch
                @hutch73959
                Hi Colin,
                Like the model looks like the real one!
                Have used a putty to fill the planking dips and gaps, will use Feast Watson sanding sealer for the hull inside,this is a top brand sealer.
                Will pull a stocking over tight and use the sanding sealer to bed it down then epoxy paint for the finish coating.
                I think this will give me a strong hull, that will outlast me.
                Cheers For now
                Hutch
                #74686
                  Colin. Organic boating. Well that takes us into the 21st century!
                  I might try a hollowed out cucumber next………..
                  ​Stocking. I would not want to rub down the hull and touch the stocking as I cant think that the nylon will rub down very well, just as a thought.
                  Edited By ashley needham on 28/12/2017 17:02:39
                  #74694
                  Byron Rees…(Ron)
                    @byronrees-ron
                    Hutch,
                    I use stockings a lot (No comments guys!!!) and a double layer (Done one at a time) makes for a very strong hull. Some sanding sealers, mainly older French polishing types can make the nylon go a little slimy so test on an offcut first. Acrylic floor varnish which often has a milky consistency or PVA white glue thinned down a bit for brushing are worthwhile and cheaper alternatives. All available down under.
                    As mentioned above by Ashley careful as you sand down stockings as a hole (or ladder) is a pig to cover up. Give it five or six thin coats and let dry and only use very fine (200 or more) grit paper.
                    Works a treat.
                    Cheers………….Ron
                    #74703
                    hutch
                      @hutch73959
                      Hi Ron,
                      Its nice to know someone else is down under.
                      Thank you for the info went to Bunnings got a tin of British Paints water based clear varnish 250 mils $11.10.
                      I am still filling the the hull hollows and dips ,when that is dry will think about the stocking maybe a black one as Ariel's hull was black!.the final coat will be mat finish apoxy paint rattle can.
                      Cheers,
                      Hutch.
                      PS Happy New Year to you all .
                      #77280
                      hutch
                        @hutch73959
                        Hi Guys
                        Update for my Ariel build
                        I have been busy building a model train layout for our local AMRE show that's held every June long weekend.
                        So far my better half has made the 21 sails these will have a rope sewn around the four sides on the edge so the sails can be fixed the spars and folded depending the the wind strength,with snap clips on the bottom corners to make this easy to do.
                        The hull is waiting on undercoat and top coat the sub deck is ready for planking with 3mm thin wood strips
                        The brass/wood winches,and brass /wood bilge pump kits are made, only the brass/wood windlass has not owing to the not all the wooden parts not being in the kit? this find a bit strange.
                        Hutch
