If you already have the cloth it is quite possible that it will be intended for use with polyester resin. Using epoxy may case problems – something to do with the coating on the cloth I think.
You say you have glass cloth – do you mean tissue, as that is the usual covering for the exterior? Some people also coat the interior with resin at least while Glynn Guest on this Forim prefers to leave the inside untreated to let the wood breathe if moisture does penetrate.
Fastglas resin available from places like Halfords in the UK is a quick setting polyester resin and you can get matching tissue as well.
Once it’s on and set it’s not easy to get off so you need to get it right first time! Neil Howard Pritchard on this Forum should also be a ble to give you some useful tips.
