My 3 youngest grandsons, who live in Sydney, asked me to build them a rescue boat in case their other boat failed mid stream. I decided that a pusher tug was the answer, as I have a bigger one of that type which is used as a club rescue vessel.
The boys’ boat needed to be fairly simple, with only basic detail, to avoid the risk of damage by small fingers. I also wanted to keep the mechanical side simple, too, so I opted for a single prop with a Kort nozzle, and a decent size rudder for good control. My own pusher has 2 motors and props with “tank” steering, but I thought that setup may be a bit too challenging for the younger members.
The boat was not built from a plan, but “out of my head”, just making it up as I went along
The hull has 12mm pine sides, bow and transom, with 1.5mm ply bottom. The bottom has fibreglass reinforcing on the inside. The deck is 3mm lite ply, while the superstructure is 1.5mm ply. The hull has self adhesive foam tape all around to protect vessels being recovered.
The Kort nozzle is from 40mm PVC pipe, and I squared off the tips of a 35mm prop on the lathe to fit inside the nozzle. I made the prop shaft assembly myself, as is my usual practice. The motor is a basic 550 type, with direct drive to the prop.
The transfers (or decals, if you prefer) are printed on to clear decal paper on my PC, and include one with my son’s address and phone number, should the boat go AWOL.
It was quite a simple project after my Armidale class patrol boat, and much easier than my next model, a 1/20 scale scratch built RNLI Severn class lifeboat.
Peter.
