Hi Derek
I steamed my plywood skins over a kettle, support each end and weight it in the middle.
Over bending is OK as it is easy to pull into the boat frames with clamps and rubber bands.
As for motor for the boat a 35-36mm brushless for a bit of performance.
The Hobbyking 3639-1100 or 3648-1450 which are a straight change over.
ESC a 100 Amp to handle up to 6S.
Battery 3S or 4S 5800mah 40C.
Prop 38-40mm 2 blade is a good starter.
I found the 3 blade props use more power, but, better slow end speed.
Battery position behind the step down in the cockpit area.
I have not installed trim tabs as I think they are not required.
I maybe wrong if I go to 4S,but, I think the boat is fast as it is !!!
But me being me I will have to try it !!!
Checkout my post Precedent Huntsman 34
Harry Smith
