Colony Class cruiser
Home Forums Scratch build Colony Class cruiser
  • #12958
    Bernard Allen
      @bernardallen88612
      Hi,
      A couple of months ago, I decided to build the above model as published in Model Boats April 2004.
      I am now coming to the end of most of the superstructure before starting on the deck fittings.
      I wish also to  wish to show  a number of portholes.
      Glynn Guest’s plan and photos show portholes but detail isn’t sufficient to show whether they are just black dots as a representation or actual drilled holes.
      Thanks for reading this.
        Bernard.My modelling at home is of the "fit it in where you can" school of boatbuilding. I like the "glynn Guest" method, as most of his designs are stand-off scale, and you put in as much or little detail as to your personal taste. I seem to recall this feature, cant remember the porthole bit, but would take an educated (or not) guess that they were dots. I think regardless of what was on the plans you should do what you think you will be happiest with at the end of the day. My Titanic only has painted on dots (in fact they are marker pen via a template!)and squares for the windows and portholes, looks fabulous floating on the pond, not so clever close up…but there again I didnt spend hours and weeks doing it! Ashley
        #12977
        Len Ochiltree
          @lenochiltree67043
          Hi Bernard,
          You will feel better if you drill out the portholes,ifyou just paint them you will always wonder if only………
          Len.
          #12981
          Bernard Allen
            @bernardallen88612
            Thanks for that Len, this is what I thought and would probably look better as well.
            I have found out that the published pictures show black gloss paint dots. Bernard.
            #6443
            Bernard Allen
              @bernardallen88612
              HMS Tanganyika
