Thank you Paul and Ashley.
You see, I am an ex-aeromodeller and for an aircraft, a nominal centre of gravity is always calculated (usually just in front of the thickest part of the wing chord) so that the first flight has a reasonable chance of being successful.
I understand your points about moving the ballast (batteries) about on a trial and error basis, but I wouldn’t think a full size boat architect has the same luxury, and needs to calculate some sort of balance point before it goes into production.
OK, we’re talking models here – its just that I like to get things right from the start if possible.
That said, I have no argument with your advice and I guess a static test in the bath when the hull is painted is a good starting point.
Thanks again gents,
Brian
y
