can anyone help
can anyone help
Home Forums Beginners can anyone help
  • #1902
    boat building disastor
      @boatbuildingdisastor
      need help
        i have a model of the dante
        Dante
        Click to enlarge
        This
        new addition to the Compact kit range is to the slightly larger scale
        of 1/72 to give more working room in the model and to make the kits
        more suitable for the railway modeler.
        The details and construction methods used in the craft are the same as in all the kits in the Compact Kit range.
        This craft is based on one of the ships used in the petro- chemical port of Euro-port in Holland.
        The ships are constructed by the DELTA shipyard to a standard design
        and personalised by the buyers to suit there own needs. This example of
        the type is designed as a fire-fighting and rescue ship. She is fitted
        with powerful water and foam monitors, the one on the top of the mast
        being telescopic.
        She is also fitted with fast launch and
        recovery R.I.B.s in quick launch davits. On board she is also fitted
        with powerful suction pumps and a decompression chamber.
        The
        ship has two powerful diesel engines driving twin screws and are
        capable of handling most disasters on the largest of ships in confined
        waters
        Details of the kit
        Scale 1/72 Length 320mm Beam 115mm Sailing weight 857g
        i need some help with making some scale water monitors is there anyone out there that has the time and knolage to do this for me please get back to me 07724743882
        #22626
          BBD. Monitors are easy to make. They consist or a post and bit of pipe on top. Make the post out of dowel, can stick a bit in a power drill and use it like a lathe to taper it down with a file or sandpaper, epoxy a bit of brass pipe on and stick the thin plastic tube from the pump on one end and bobs your uncle.
          OK, its not quite that easy, but its much easier than making a convincing 40mm Bofors or something. Once its painted red, no one will will notice. have a go. Windscreen washer pumps for squirty power. No probs.
          NB alternatively, have a surf, must be something out there of the right size.
