Building with Craft Foamboard
Home Forums Scratch build Building with Craft Foamboard
Viewing 25 posts - 101 through 125 (of 172 total)
  • #40857
      Paul. Nice job. Shame about the yellow paint.
            I was very pleased with the flag effect artwork but the yellow paint has ruined the entire effect.
                LARRY WHETTON
                  @larrywhetton68737
                  Hi Paul,
                  Very nice , it would make a nice free plan feature, get Colin on board,
                  it would make nice change , from grey boats ,
                  if there…
                  is a plan i am keen , a good young modler build……….for school prodject .
                  by the way i hope you are better…. cheers Larrry
                  #40900
                  LARRY WHETTON
                    @larrywhetton68737
                    Hi Paul,
                    if there…
                    #40938
                      Hello Larry
                      I am feeling much better especially now that the dressings have come off my foot and thank you for asking.
                      I haven't produced plans for my hovercraft as my model is close to Mark Porters Griffon design, I simply knocked up the craft as a test bed for building with foamboard.
                        Hello Larry
                        LARRY WHETTON
                          @larrywhetton68737
                          Hi Paul,
                          Thank you for reply, and info , where do you bye board..?.. Larry…
                          #40970
                            Hi Larry
                            At the moment ebay is the cheapest
                            Ian Gardner
                              @iangardner62867
                              Paul, the hovercraft looks great and I bet we're all on tenterhooks to hear how she performs. Having returned this morning from our new water without having wetted a boat's bottom because of weed, I may have to think again about a hovercraft!
                              Anybody know how to get rid of weed!?
                              #41003
                                The hovercraft performs quite well but needs more lift power so now I am playing around with different lifting fans to see which works best. I realise that in many ways I am 'reinventing the wheel' but I do enjoy this kind of research.
                                The only eco safe way to remove weed is to rake it out….hard work!
                                Edited By Paul T on 13/05/2013 07:07:36
                                #41091
                                  One unexpected problem is that the hovercraft is rear heavy and even when I balance up the model without the thrust motor in it still sits heavy at the stern.
                                  I am confused as to why this is as the entire superstructure is equally balanced around the lift motor and there are no gaps or rips in the skirt.
                                  I need one of Bobs eureka moments.
                                  Larry I have sent you a pm about this model.
                                  Edited By Paul T on 16/05/2013 16:00:46
                                  #41092
                                    Is the airflow from the fan balanced under the skirt or could you be getting some sort of directional eddy which affects the balance?
                                      Good point Colin
                                      The computer tells me that the airflow is rate is balanced but I'm still playing with different fans so I might be getting lumps in the airflow.
                                      Perhaps some alterations to the sub chassis might be required.
                                      Amy jane September
                                        @amyjaneseptember49770
                                        Hello Paul
                                        Just a thought on your fan experiments. Have you considered making a fan that blows the air side ways, centrifially off it's perimeter, and deflecting it down wards around the skirt, (this is the way a flymo mower works) rather than blowing it directly downwards. It is the pressure difference between the underside of the hover craft and the atomosphere than keeps it afloat, (you know this already of course!) It doesnt take much pressure diference, but requires a lot of air volume to maintain. I say this on the basis of my husband having converted two stroke flymo lawn mowers to four stroke, and by making a fan that shifts a larger volume of air the heavier and slower turning four stroke could be made to lift very well indeed. Just a thought.
                                        #41107
                                          Hi Amy
                                          That might just be the answer I will design a plenum chamber and give it a go.
                                          Thank you for the very welcome input.
                                          All the best
                                            I hate to say it, but perhaps some ballast at the front migh help?? I know this is counter to keeping the weight down, but is an option.
                                            A grid or shutter arrangement under the lift fan might be able to diffuse the air to parts that normal air cannot reach.
                                            very intersting this and I am paying close attention.
                                            My srn4 prototype was nose down when moving forward, and the lift fans were at the front. the skirt was solid so???
                                            The rear fan could have a small deflector/flap/wing to provide lift at the back?
                                            is this back down attitude at speed, stationary, or over land or water?
                                              Paul,
                                              I think Amy Jane is right. I did a bit of googling last night and it does seem that the design of the plenum chamber and air distribution has a significant effect upon the balance of the craft. To use an upside down analogy, think of a shallow rectangular baking tray with water in it – the whole thing is very unstable and the water slops about with the slightest movement ,completely altering the balance of the tray.
                                                Do Griffons have a plenum chamber or does the air just get dumped onto the ground surface… ? Never looked..not thought much about it before.
                                                Paul, photo of your bottom please so we can see the underneath layout for my education, thanks.
                                                  Oh Ashley be careful what you ask for…
                                                  Colin put your editing hat on standby.
                                                  #41112
                                                  Telstar
                                                    @telstar
                                                    Hi Paul Just a thought, If you fitted a plenum chamber directly under the fan, "sealed" then ducts from the plemun out towards each corner, by putting adjustable dampers in the ducts you could perhapssmile p balance the "thrust". Alternately perhaps series of baffles to split up the underside to prevent the "sloshing" about (see Colin's post)
                                                    Cheers Tom
                                                    #41113
                                                      Hi Tom
                                                      Thanks for the idea it has given me more food for thought.
                                                      Cheers
