paul, a moder Lipo would fit underneath the hulla s they are very thin. gear could go in a more solid cabin, and even the front ducts could be used, as the craft will spin easily and so not need reverse.
A solid/slotted bottom would be fine on a lake, and this would become almost a skimnmer if there was sufficient forward propulsion.
What a great project for foamboard…ideal I would say !!
Thinking about it, only a modest lift would then be needed and some small ducted fan units would sit comfortably in the ducting bend, to provide the thrust rather than bleeding off lift air. Small gear should easily be accomodated in a slightly fatter hull surely..? Seperate thrust units will do away with servos and linkages.. cor…on me list!
