To answer your questions.
From the baseboard to the top of the stringer at F7 is 179mm…..True measurement is 177mm
From the baseboard to the top of the stringer at the transom is 190mm…..This measurement is also 177mm
I am keeping the stringer full length for accurate continuity and reducing the side plate height accordingly…..Keeping the stringer might throw the accuracy out as it will have an effect on the shape and position of the stringer in other locations (running it through the CAD shows a +/- 2mm deformation between F5 and F4)
Looking at your photo the transom is in the wrong position as the correct location is governed by the 177mm dimension (which on your build is baseboard to the top of the stringer at the transom )
I hope this makes sense.
Edited By Paul T on 15/01/2014 19:35:27
