Hello Ashley
Decided to sail Brutus today….Just for you and for another reason
Sure enough!……Brushless motors are playing up again!
Got onto the suppliers
The man said…… ".For 7,2v supply, it is already set up!….Simply connect up and go…..No setting required"
He also said…….".Don't use a tranny with the ratchet type gymbal,,,,,,,,Use the Elevator stick….To make use of the self centring feature"
Reset the good motor just to check out the proceedure on the Elevator stick and it worked ok…..But this motor was ok on the original setup
Tried the troublesome motor, but it didn't work!
I suspect the Esc is faulty
Will wait now for SloMo to be wired up and follow the latest instructions exactly
Don't want to corrupt the new gear with old settings
Why don't the Brushless motor dealers issue intelligent clear instructions written in English?
There are thousands of brushless motor set ups out there, all running nicely…..So we only need the correct instructions
