Brutus
Brutus
Home Forums Scratch build Brutus
Viewing 25 posts - 551 through 575 (of 1,017 total)
  • #47301
      As far as my limited knowledge goes I don't think that brushless motors create any interference so there shouldn't be any proximity problems for the receiver.
      However owing to weight issues I would advise that the receiver is placed in the forward section (bay 3) and the battery pack for the cooling system would be better just forward of the fans themselves fitted low down in bay 4.
      This would leave the area between F5 and F6 clear for the main batteries which could be fitted across the width of the model sandwiched between the shafts and ESC shelf. I realise that this makes thing very tight in a small area but you might find it necessary to get the mass of the batteries in that location in order for the model to perform correctly.
        Thanks Paul
        Will be buying a few of the smaller 7,2v batteries at Ellesmere, to put in the motor compartment this weekend and will pick the brains of the Brushless experts for their comments and advice
        I checked at the club last night and it seems that the close proximity of the motors won't upset the ESC's, but I'll put the ESC's in the forward compartment anyway
        Hope to meet you this weekend?…..We shall be there, Saturday and Sunday
          Did you do the bath test? I am only shooting in the dark regarding battery positions and a float test will provide the answers.
          I am hoping to get there on Saturday afternoon but I've put my back out and cant get into the car. I will stoke up on painkillers and do my best.
            This what the Doctor ordered!…………..The bath test!
            All went well as we expected!
            First test……Fully laden with the big batteries and no leaks either
            It seemed strange, we normally pile the ballast in on bath tests!
            Water level 50mm up from the bottom corner……….How`s that Paul?
            Water level about 4mm over the stern edge
            With the smaller batteries and the ESC`s further forward and the fan batteries likewise, we should be laughin`
            #47311
              It looks very good and sits nicely on the water, I estimated that the bow should draw about 60 >65mm so your model is almost there.
                Bob. My experience with unusual models leads me to rely nothing about bath testing and I would wait for motion tests before even considering where to put the batteries permanently.
                PS You need a bigger bath…
                . Ashley
                #47315
                  I am somewhat downhearted by your comments as I have spent many hours designing Brutus and getting the hull balance just right.
                  I don't just throw these things together.
                  #47317
                    Paul. My apols. Did not mean to suggest that you had not considered the dynamic aspects. I am not used to people fully designing boats in all their particulars using the tools like wot you do.
                    I will collect some birch twigs and beat myself for even considering that this might not be the case (not that I was suggesting this in the first instance)
                      Got you smiley
                      #47320
                        Its no good I shall have to add you to my list of people to hate forever and ever.
                        It has Bob on it as he was similarly as cruel.
                        There is room for more, especially in the matter of h#######d.
                        Ashley (returning next doors birch sticks to the green bin)
                        #47321
                        mike farrell
                          @mikefarrell21522
                          Thanks Bob for the info will use as a starter. As for esp next to motors I used them in our R.C racing cars and never had problems with close proximity of either but had some small glitches when near to receivers .Added ferrite rings to cure the problem
                          Enjoying the build ,well done both.Michaelwink
                          #47323
                            Thanks Mike
                            That`s nice to know and will remember the ferrite ring trick too
                            When you`ve stopped larking about……….Some time ago you mentioned the three wires from the ESC and having to swap them about?
                            Well, I`ve got the same problem……Three blue wires from the ESC to three wires on the motor….red…yellow…black
                            Don`t like the Trial and Error method……..Any ideas?
                              Bob. I dont think it matters which wires you connect up, so just connect any wire to any other wire. In any event there are three unmarked blue ones from the ESC so you have no choice.
                              However if the motor revolves the wrong way to which you want, you simply reverse ANY TWO wires!.
                                Thank you, Ashley
                                When I`ve connected all these wires together……What is the next step?
                                Looking at the instructions, there seems to be a lot of setting up involved, with plenty of alternatives
                                Is there anything I should be aware of, before I start pressing buttons?
                                I think this is the reason why Paul and Dave M and me too…..Have shied away from the brushless option!
                                  Bob. I think the ESc will be set to plug`n`play BUT it will be set for Lipo batts likely, and so have a low voltage cutoff setting possibly unsuitable for Nimh batts.
                                  The best and easiest way to sort this is get a PROGRAM CARD for the ESC. You simply plug the esc into this card, power it up and be able very easily to set a few things like reverse, voltage cutoff and so on. You probably will not have to alter a lot. They are not that expensive, and the options on it will be set out easy to see and to pick out..
                                  Doing the programming of the ESc on the transmitter by twitching sticks and listening to ESC tones is confusing and tricky ….
                                    Thanks Ashley…..The plot thickens!
                                    Luckily, we`re off to the show tomorrow and I hope the Brushless gear supplier will have a stall there
                                    There must be others too
                                    curly
                                      @curly
                                      Hi Bob
                                      If the motors and ESC you bought from Vintage Models, they are set up for 7.2 volts, and don't need to be set up. If the rotation needs to be reversed just swap any two wires I hope this helps.
                                      All the best at the show this weekend
                                      Curly
                                      #47342
                                        Many thanks, Curly
                                        That's nice to know and you make it sound so simple!
                                          Looking at your pictures of the high speed fire boat at Ellesmere Port, going through it's paces, has got me thinking!
                                          The fire boat looks light at the front and is almost leaping out of the water!
                                          Brutus will be even more so, but we don't want to do any leaping!….We hope to chop through the waves!……Almost like a Resurgam!
                                          So why have we got the light nose up effect?….I would have thought the reverse is the way to go?
                                          No doubt there's a perfectly logical reason coming up!
                                            Sorry Bob but can you be a little more specific.
                                              Now, Paul……..I think you are winding me up?……You know what I'm getting at!
                                              Brutus is very bulbous at the front and quite light, which means it will run up and down the waves?
                                              If we had some weight up front, we will surely plough through?
                                              You take it from there!……Brace herself, chaps, I think Paul is about to go ballistic!
                                                Its a perfectly understandable question especially give the unusual design and rather than smother you in techno babble I will simply say do you recall our conversation at Ellesmere Port where I compared Brutus to a canoe
                                                Just like a canoe Brutus has a large underwater surface area and as such floats high in the water and just like a canoe its 'bobbing' action is limited by the hull length.
                                                Also like a canoe most of the weight in Brutus is concentrated within a small area which allows the hull to rise and fall around this mass, adding weight at the front will make it bow heavy and actually increase the propensity of the model to 'bob'.
                                                However all of this is theoretical until the model gets into the water.
                                                I hope this helps
                                                  Some interesting thoughts there Paul but surely you could reduce the pitching effect if it is possible to concentrate the weights at the ends or at least spread them along the length of the hull – easier said than done I know and you wouldn't put the weights at the extremities on a full size ship but you can of course get away with it on a model.
                                                    Thank you Paul
                                                    If it`s any consolation……….Should the model fail to live up to expectations……….. I won`t be upset whatsoever, so don`t you worry about it
                                                    Never mind the time and expense, we`ve had great fun over the last few months and that`s all that matters
                                                    My thoughts are, that without a keel and lacking weight up front, the boat will sheigh away from the waves, but this can easily be corrected……If not, then it`s the Pearly Gates with no regrets
                                                    At the moment, progress is very slow, because the way ahead is not clear cut and Ellesmere is behind us
                                                    I`ve tidied up the rudder mech, fitted the main batteries, fitted the fan battery
                                                    The wiring needs to be neat and tidy……..Then the fireworks will start!
                                                    I still have high hopes for success
                                                      Look at the canoe on the right
                                                      The same hydrodynamic principals that apply to this hull also apply to Brutus, the canoe doesn't have a keel and it glides over the water rather than plough through it. The difference with Brutus is the extended bow but the science remains the same.
                                                      Brutus will almost fly in a straight line and tight turns will be an adventure.
