Brutus
Brutus
Home Forums Scratch build Brutus
Viewing 25 posts - 426 through 450 (of 1,017 total)
  • #47033
      Bob,
      I bought some, on Ian Gardners recommendation, as a first covering for the card plating on Guardsman. It is also being used on the balsa cabins etc. Applied it before painting, everything Ashley and Colin say above is correct. A superb product which I will be using a lot more.
      Tony
        Thanks a lot boys………………………. Ashley, Colin, Dave and your good self Tony
        It must be good
        Ian Gardner
          @iangardner62867
          I have never used Eze Kote. I found Poly-C -an alternative product which was bit cheaper at the time and used it in conjunction with nylon tights. I found it dried quickly, built up a good finish over several coats which can be applied rapidly and takes a paint finish well. It is an acrylic finish which cleans up with water and is very low odour. It also goes a long way.
            Thank you Ian
            It looks very similar to Eze Kote
            Latest WIP pictures for the Drawing Office
            The last big construction job is nearly finished…….Still got the windscreen area to sort out yet
            We can expect to see a few eyebrows being raised on launch day!
            The rear curved section was a struggle, with no means of using clamps!
            This is where I`d like to see an air vent, Paul?
              I wouldn`t be surprised if EzeKote is only PVA watered down?
              Is this possible?
              I don`t really fancy soaking my model in water, it could easily distort
              Is this possible?
              Just thinking out loud
                No Bob it is an acrylic water based resin suitable for laminating as well as sealing. It is sold as an alternative to Epoxy resin and as a sanding sealer.
                It won't distort your model.
                  Thank you, Colin
                  Much obliged, I suppose it would be wise to do small areas, to avoid the risk of distortion?
                  Will let you know
                    Don't believe me do you?! wink
                      Bob. Dont be a ninny. Slap it on, there will be no distortion. Probly do more damage by only doing small areas at a time in any event.
                      Vents a bit low for me, also need an inlet and outlet I would say on the cabin. A couple of low mushroom vents perhaps to stop water flooding in as you plough through all those waves like…..er….the big ploughy thing that it is.
                      Alternatively use a smaller slot vent somewhere and a computer fan to provide a bit of suck and blow?? And a nice bank of turbine exhausts to exit the air from !! devil
                      Edited By ashley needham on 10/02/2014 19:55:29
                      Edited By ashley needham on 10/02/2014 20:00:52
                      #47047
                        Hello Rear Admiral Bob
                        The rear of the cabin looks exactly as planned and I am very pleased with how it looks. The low profile windscreen echoes the basis of the original inspiration for the whole design.
                          Thanks Ashley
                          OK…….I`ll slap it on then!
                          Paul is Adam Ant about where and what the vents will look like
                          I really must follow his instructions to the letter, to keep the model a Thorough bred!
                          Paul has gone to enormous trouble, designing the Brushless motors layout and cooling fans, even the internal vent ducting, I couldn`t possibly make any changes
                          The model looks very special and building it, has provided me with enormous pleasure…..and is keeping me young!
                          I have to confess though, quite often, I get up at ungodly hours, like 5.00 am and start work…….Quietly of course!
                          Sometimes I drop something!………Then there`s hell to pay later!
                          Rear Admiral Bob……..Note my recent promotion?
                          #47049
                            Bob. Of course, only joking. Paul is ignoring my ridiculous proposals anyway, I can tell
                            Cooling fans?????
                              Looking at what B&Q have on their shelves for sanding sealer etc…..They have a vast array!
                              I'm thinking they would have the right stuff and it's very local to me…..So is Halfords for the spray paint
                              EzeKote would cost me £38 via mail order and involves a lot of messing about on the net!
                              No contest
                              Will give it a try today
                              All we need now is to settle on the colour scheme
                              Paul….You say black and grey……But the window is black,,,,Do you mean….Dark grey and light grey?
                              What about underneath?……White?
                              LARRY WHETTON
                                @larrywhetton68737
                                Good morning Bob,
                                Brutus looking good, but not only a timber muncher getting a bit of money pit,,,.surprise
                                cheers Larry…
                                #47052
                                  You don't need to buy Eze-Kote from Australia Bob! You can get it for £16 or so delivered on several websites.
                                    Thank you, larry
                                    I don`t mind spending the odd quid on an interesting hobby…….We can`t take it with us!
                                    You look after yourself, Larry and keep popping in with your hints and tips
                                    Thank you for your helpful hints and I do appreciate your advice, but we are only talking grain filler for a model boat
                                    And I do like an easy life
                                    I went on the recommended website for some EzeKote this morning, but didn`t fancy giving my Visa info to another third party
                                    We`ll be OK
                                      Bought my Eze-kote from W.Hobby (London), not always the cheapest but a supplier who has been around many years.
                                      #47055
                                      LARRY WHETTON
                                        @larrywhetton68737
                                        pc170011.jpgBob ,
                                        I use a tub of tile and grout from local diy, on plank on frame for fine tuning , and hase it says on the tin water proof when dry sands easy and a good grain filler try a bit on balsa, also when i built JENNY covered with a nylon stocking coated with pva glue , smoothed over t/g , sand with graded sand paper couple coats off rattle can under coat , wet dry , between coats . then finish coat gloss , see pics,,….cheers Larry.
                                        #47056
                                          Thank you, Tony and Larry
                                          Just as I predicted……..Anything that can fill a crack………..Is fit for purpose!
                                          We`ll be off shortly, when this blinkin` rain stops!
                                          Noah
                                          #47058
                                            Dear All
                                            As you are all aware Bob has decided to go brushless which means a pair of ESCs that get very hot and need to be air cooled. The following image is of a pair of cross sections showing the position of motors, escs, additional cooling fans and most importantly how the cooling air flows through the model.
                                            Air comes in through the hidden recess at the top of the windscreen and is pushed through the model and over the ESCs by twin 80mm cooling fans positioned at F4 the warm air then blows out of the model through a slot vent in the rear of the cabin.
                                            The interior of the cabin has been modified to create two plenums, one for the intake and a smaller one for the exhaust.
                                            The ESCs have been shown fitted on a shelf, this location allows the ESCs to be positioned within the airflow and so maximise the cooling.
                                            As the brushless motors are quite small I have been able to reposition them closer to the bottom of the model and with an associated slight change in propshaft angle have been able to achieve a direct drive.
                                            Edited By Paul T on 11/02/2014 13:41:51
                                            #47060
                                              Hello Paul
                                              It would have been better, if you had split your drawing and put the cross section above the side elevation, for a larger image
                                              I`ve ordered the two fan units, as we discussed. Are you aware that the ESC`s each have a mini fan built in?
                                              I don`t understand your idea of a hidden air vent in the window area. The windows will be dummies and are simply glued black plastic.
                                              How about a couple of labyrinth vents in the roof?
                                              Cabin now finished. Working on the Fore deck………Gluing a set into the "flat top to curved area"
                                                Yes I know that the ESCs have mini fans I got onto the manufacturer to find out how much air and heat they move.
                                                The air intake in the cabin roof / window is exactly as drawing that I sent to you. Even though the windows are dummies they are now recessed by 5mm which creates a hidden gap across the top of the windscreen. This gap has sufficient area to allow for the correct quantity of air to enter the model.
                                                Edited By Paul T on 11/02/2014 15:33:12
                                                #47063
                                                  We have our little ups and downs, don`t we?
                                                  Here is the cabin…….If I cut where you are telling me, the window will distort!
                                                  Unless I`m misunderstanding you?
                                                  Let`s have a roof vent?
                                                  #47064
                                                    I see what you mean about distortion to the window but it is very important that we don't use those horrible scoop vents as nothing looks more like an afterthought than those things.
                                                    Do you think that a supporting frame could go behind the wraparound windscreen to prevent the distortion?
                                                      Don`t want to touch the window at all…..It`s highly stressed at the moment
                                                      A couple of pix…….
                                                      The rear vent opening……..Will be very nice with a plastic grating or similar
                                                      Something like this….or half moon shaped, to match the front?
                                                      Anything but a poxy window slot!….lol
