Hello Captain Bob
Firstly don't worry about the build as it is going exactly as envisaged.
To answer your questions
I never intended this hull to have an external keel and I fully expect the hull to be skittish when making high speed turns but this will simply separate the men from the boys.
Our discussion about sponsons related to a warship derivative of this design, which is still kicking around in the back of my mind, and are not needed on this particular model. The whole point of the Brutus design from an atheistic point of view is that it has a single long hull.
The keel is this curved shape in order to keep the bow in the water whilst the rest of the hull rises onto the plane (or semi plane) as shown below
The curved design of the lower hull is quite a complicated shape and took some time to achieve, this is due to the changing water contact point (the contact point moves toward the stern as the boat accelerates)
And lastly, but still very importantly, the bow is exactly 90deg vertical to the foredeck and knife sharp.
