Captain Bob
The plan that was issued with the magazine is different to my original design.
I doubt that anymore than 30% of the readers know what a 5 thou feeler is and are probably thinking about an obscure 1980s Swedish film for discerning gentlemen.
Lady Joyce is a typical displacement hull and you could easily add 6ft to it without changing its ability to sail.
Brutus is a hybrid hull and specifically designed to be the size that it is, adding or removing 6in, without redesigning everything else, would significantly change its sailing characteristics and to use an analogy, instead of having a Gazelle you will end up with a Hippo.
The length and width of the hull along with the positions of the motors, batteries, propellers and rudders were carefully worked out to ensure the boat performed in the way that was intended.
You could use thrust tubes as rudders, similar to kort nozzles they fit over the props and move like rudders, not only steering the boat they will also contain the prop wash and increase the thrust.
