BRUTUS MK 11
BRUTUS MK 11
Home Forums Scratch build BRUTUS MK 11
Viewing 25 posts - 51 through 75 (of 532 total)
  • #88998
      Hello Bob
      Now that you are carrying the mantle of Chief Designer you will have to be more precise about your measurements,
      Four laminated layers equal 12 mm
      You haven't included the glue between the laminations wink
        What are you on about, …Chief Designer.,……..I haven't got any wood at all now, and hardboard is keeping the build going
        It looks OK to me
          Bob. The hardboard will be fine, just make sure it is well sealed. Use thinned undercoat first etc.
          In theory, if you steam it, it will bend to fit some of your curves. In fact, if you had a mould, it is just possible that you could press it into shape(s)…..?
            Thanks Ashley
            I`m quite happy with the hardboard strips, the Evostik is doing a great job and it sets like concrete
            It`s quite rewarding building a boat out of recycled materials
            I`m about to order the 1mm plywood now, then it will take off!
              Latest picture of the epic stringer build
              It feels very strong now and looking forward to the ply sheeting exercise shortly
              #89049
                More progress pictures. I realise they all look the same lately, but progress is slow but sure!
                Now we`ve come to the Transom area, going off the last build, I recall, we had a problem at this end Mm?
                Will to get the old pix out
                Paul…….Is the latest Transom frame correct?
                The stringer notches look suspicious
                Edited By Bob Abell on 14/06/2020 09:06:17
                #89052
                  Hi Bob,
                  I think you maybe building a Thames slipper launch, it looks similar 😄
                  Keep going you will get there 👍
                    I'm sorry to say that I am not sure as it was so long ago
                    But after extensive research on the dark web and at great personal cost I have found part of an amazing and mystical archive that is full of construction photos and might just be the answer to your problem.
                    These images clearly shows the part in question and how the builder overcame these problems, if only we knew who this master builder was as his full archive could answer all of your questions.
                    #89062
                      Thanks Paul
                      I already have your photos
                      I'll just struggle through and sort it out
                        I do remember some discussion about the transom when you built the first one, in retrospect I should have given the stern greater depth but at the time I had a fixation on making the stern appear to slide into the water.
                        Like Ray said it was very much like a slipper launch.
                        There is a possibility that I changed the design of the stern in order to overcome construction problems but these changes would have been picked up on the drawings that you are using.
                        I will go back to the thread that covered the original build and see what was said and done but meanwhile could you explain what you mean by The stringer notches look suspicious? Are they too big, too small, in the wrong location or just baffling
                          Hi Paul
                          I`ve got it sorted out now
                          Not much of a problem, the problem was caused by me thinking the sponson shape was correct
                          The notches on the sponson were such that they rested on top of the upper stringer
                          Anyway, see my latest progress photo
                            frame 1.jpgThe frame is just about finished now, needs a bit of trimming here n there, but….
                            It has turned out better than expected, considering that it is made from Hardboard mostly
                            Now for the sheet covering, now that the shops may be open again?
                              Hello Captain Bob
                              It is looking very good and a lot more substantial than the original, where are you planning to fit the forward rudder (between frame 1 and 2?)
                                Thanks Paul, I like it too
                                Got the Transom sorted out now, I just removed the outer tabs and it was kinda obvious after that
                                So you like the idea of a forward ish rudder, afterall?
                                I think it will be ok between Formers One and Two and will be nice to see how she behaves?
                                I`m hoping to fit a cannon, in line with the rudder shaft so that it can rotate with the rudder?
                                At the moment, we`ve got a tremendous rain storm here with buckets of Hailstone too!
                                Keep safe, out there and all the Forum readers too
                                  Hello Captain Bob
                                  Yes I like the idea of a forward mounted rudder especially when used with tank steering. One problem though could be protecting it from damage as it will be very exposed, There is an obvious and simple modification that would protect the rudder and help with straight line stability but I don't want to interfere with your super build as you could already have a better idea.
                                  We had hailstone last night, big bug-ers and sounded like someone was throwing gravel at the windows.
                                    Hope to receive the thin ply today…….From SLEK
                                    Got the hull bottom in a ship shape condition
                                    The workshop is looking very busy once again….See picture
                                    #89175
                                      Hi Bob,
                                      Your going to need some more shelves for your models soon 😄👍
                                        Hi Ray
                                        I do have another play room next door, but no shelves and no wood either!
                                        Have you noticed how the shelves are all held together with an assortment on clamps!
                                        Look after yourself
                                          Good Afternoon Captain Bob
                                          How thick is the ply?
                                            Hello Paul
                                            I've ordered 1mm, 2 mm, 3 mm 4 mm and 6 mm
                                            I'm hoping the 1 mm my will do the job
                                            I know you won't agree but wth suitable supporting strips, the 1 mm wil be ok?
                                            If it looks a bit too thin, them I'll get some thicker stuff
                                              Bob. 1mm should be fine if supported by ad-hoc supports. It may bow a bit but this is very realistic, google pictures of warships in the sun and you will see the wobbliness of the plates nowadays.
                                              If only Bob made some boxes for his boats they would stack nicely on the floor (upwards) and having cord or rope handles on them would make them much easier to lug about.
                                              Bob. Please remove the clamp and fix the shelf properly please!! You are an engineer….
                                                You have built a substantial frame with plenty of stiffness so 1mm ply might be thick enough, the only downside might be impact damage when the hull hits an obstruction.
                                                  Thank you Ashley, for your concern……
                                                  er………Which clamp are you referring to?
                                                  I`ve got ten clamps usefully employed holding stuff up
                                                  Just to please you though, I`ve fitted a strut under the Slo Mo shelf
                                                  Boxes?…….D`yer think wood grows on trees?
                                                    Now don’t give me that Bob….you should have had 4mm ply in AGES ago to box up yer boats!
                                                    Its the only way to store and transport them.
                                                    Yes the Slo-Mo shelf!
                                                    As the boat you are building is another whopper then perhaps 1.5mm ply might be used especially as PT says, better resistance to unintended impacts.
                                                      Thank you, Ashley, for your sound advice
                                                      The boxes will need to be very big and hence…..Very heavy too
                                                      At the moment, they look very on the rickety shelves
                                                      Back to the real world………The plywood failed to materialise yesterday, just as I thought
