BRUTUS MK 11
BRUTUS MK 11
Home Forums Scratch build BRUTUS MK 11
Viewing 7 posts - 526 through 532 (of 532 total)
  • #92296
      Not sure..perhaps that the nor/rev switch (normal or reverse) switches are both “normal” (or however your transmitter is marked.
      Ashley.
        Captain Bob
        You are using two separate channels to control your motors and having trouble with forward / reverse on one motor.
        Presuming that the boats wiring is correct and you haven't crossed polarity anywhere the problem could be with the transmitter or receiver.
        Is it possible that one of the normal / reverse switches on your transmitter is incorrectly set (presuming that your transmitter has this facility)
        Failing this have you dropped or damaged the transmitter or receiver.
        Lastly have you bench tested the transmitter / receiver recently.
        Is Joyce fully recovered?
          Thank you Paul
          The different speeds are part of the ESC characteristics; 50 amps going forward and 20 amps in reverse
          Joyce is back to her old self now, thank you very much for enquiring
          I`m in trouble at the moment……I`ve contacted Food Poisoning at the moment
          Had a frozen meal that wasn`t quite thawed out!
          Having a torrid time,,,,,,,,,, for `n` aft!
          Getting over it now, hopefully
            Captain Bob
            Oh dear, that is unfortunate and very debilitating whilst you suffer but hopefully it will run its course (bad pun) and you will be back to your old self.
            Is this a result of your cooking whilst Joyce is in dry dock?
              Thanks Paul. Just about feeling better
              That`s taught me a lesson all right
              I`m almost frightened of quick cooking frozen meals now
                Hmmm….most frozen meals seem to be designed to be cooked from frozen, unless you froze them yourself!
                Canned food is the way to go. No preservatives whatsoever and almost an indefinite shelf life.
                Bob just get a Y-lead and have the-throttles on one stick. Will probably cure any imbalance and ensure both esc are “pointing the right way round”.
                  Please to say that I am back to my normal bubbly self now…….Thanks
                  The motor problem is just a storm in a Tea Cup and will soon get sorted out in the Spring
                  Thanks to all
