Hi Clive
Colin's advice is sound but I would soak test a small area of the keel first just in case the kit manufacturer has used a ply containing soluble glue….you don't want the whole keel delaminating whilst soaking.
Personally I would steam it as the exposure time is very limited alternatively you could weight the keel down on a flat surface in a high humidity area (shower or bathroom) where it will be exposed to the humidity but not directly to water.
There is a good chance that the keel will sort itself out without wetting if you use a substantial building board for the construction process as the frames will force the keel into the correct orientation.
Good luck
