beginning the
beginning the
Home Forums Beginners beginning the
  • #19669
    Maj.Kootstranovski.ret.
      @maj-kootstranovski-ret
      Hallo there.
      My name is Harry Kootstra,see my profile ,and I,m ready to start building the Sir Kay from Caldercraft.Now there is some confussion about the rudder build in.
      The rudder comes with a shaft that is 3.2mm and they suggest that you drill a hole of 4 mm in the hull and pass that over the rudder.As you can imagine,this is a very wobble construction.Also how to get it watertight?
      If there is someone out there who has build the boat or similar,please would you be so kind to contact me as I,m not an experiened builder.Some 15 year ago I build the Bnckert of Billing and had no trouble what so ever.Also the plan provided is not to scale amd you have to figure out a lot by yourself.
      Any help will be much appriciated
        how to build in the rudder.
        #19674
        JC Uknz 1
          @jcuknz1
          See your other thread for how I do it
