wood breaking
wood breaking
Home Forums Beginners wood breaking
  • #91791
    Paul Beeney
      @paulbeeney58354
      Hi all have not built a wooden boat before i bought a model from caldercraft
      called hm sherebourne now i have to bend some 0.8 3 ply wood round the outside of the deck called bulwarks i soaked the wood in hot water for 3 hours started to ease it round a jar to get the shape and the outside ply split it as not broken in two but if i carry on it will can someone give me any advice other than buy a new section from the supplier which may break again how do i bend tis without it breaking
      Tanks Paul
      Paul Beeney
        @paulbeeney58354
        #91796
          Hi Paul
          Without being able to see it the first thought is that you are bending against the grain.
          However I could be doing you an injustice so it would be easier to answer your question if we could see a photo or two.
          Splitting wood has happened to all of us at one time or another.
          Chris E
            @chrise
            I wouldn't just assume to buy another part as if you broke one you might well do the same with a second piece. If all else fails buy some thinner ply and laminate a part.
            Punctuation & sentences make text much easier to read.
            #91805
              I have found that just a quick steam (over a saucepan of boiling water), or a hot air gun should be sufficient to bend 0.8mm ply over even reasonably tight curves, certainly a 500ml paint tin presents no problems with the outer grain longways. A jam jar should be ok, and I have only just recently rolled a bit around a 50mm pipe (play across outer grain) with a hot air gun.
              ALSO, the curved part does not necessarily have to assume the exact desired shape if it is being glued to something else that is the final curved shape. Having a slightly curved piece may be all that’s required to lessen the pull of the ply over the shape.
                This is not a bad idea for tight bends
                #91807
                Charles Oates
                  @charlesoates31738
                  Hi Paul, it's difficult to be sure from your post whether you are trying to bend a large piece of ply, or just a small piece to make the bulwark from. I prefer to make a template from card when I'm making bulwarks, those compound curves can be tricky. When you have an accurate pattern, use it to cut the ply to shape, making the ply ever so slightly bigger to allow for mistakes. It shouldn't be a problem to bend thin ply, provided the grain is going the correct way. If soaking doesn't do it, try steaming or heat on the wet wood, then slowly coaxing the wood to shape.
                  Of course, you might just have a dodgy bit of wood, but that's rare.
                  Chas
                  #91809
                  Kev.W
                    @kev-w
                    Paul, if you are having trouble with bending plywood, try cutting the required piece from a Kellogs cereal packet (other brands available), with a good lashing of varnish or resin, this medium works very well.
                    Ashley has used the method with great results in the past, but is too modest to blow his own cornet wink
                    #91813
                      Yes, a good alternative method and just as durable.
                      Dave Cooper 6
                        @davecooper6
                        There is a bit of a fight going on here with the wood on the inside of the bend being in compression (squeezing) and that on the outside being in tension (stretching).
                        Guitar makers (aka Luthiers) use something called "Kerfing". If you look on the inside of an acoustic guitar this forms the 'shelf' that the top and bottom pieces are mounted on. It consists of partially sawn through slots that allow the wood to follow quite tight curves. Bob Abell's photo gives the general idea.
                        With 0.8mm thickness though the cuts would have to be very shallow. I would practice getting the depth and spacing right on a piece of scrap wood first. Then try heat /steam possibly with a weight on one end to ease the ply into shape. Patience is needed with Ashley's boiling saucepan approach but it does work (at least, I've used this method with hard(ish) balsa thicker than 0.8mm.
                        Good luck with your project.
                        #91833
                        James Hill 5
                          @jameshill5
                          Paul,
                          I agree with Dave Cooper with his suggestion. It was the method I used when building my tug. I used 1/4" square stringers and on the inside of the bend I used a razor saw ( or a similar narrow blade ) and made cuts as deep as you dare go. The tighter the bend, the closer together the cuts need to be but it certainly works. once in place the glue fills the slots. I shall use the method again when the need arises. If I remember correctly, I bent mine dry, but whatever else helps is fine. Give it a go.
                          Best of luck,
                          Jim.
                          #91835
                            I've used that method with timber sections but not successfully with thin ply as it tends to form a polygon rather than a smooth curve. Not saying it can't be done though.
                              We need some pictures of the hull shape you are attempting to bulwark.
                              My experience of 0.8mm ply is that it is like thick paper when hot..either using steam/boiling water or a hot air gun.
                              I rolled a100mm strip of ply around a 50mm cylinder to make an edf tunnel with nothing more than heat from a hot air gun (and leather gloves!).
                                Enough heat at the time of doing the bending makes the wood plastic enugh to bend. It should also make the glue holding plies together soft enough to let the plies slide past each other, reducing the compression and streching.
                                Of course, that kind of heat does the same job on fingers, so Ashley's stout leather gloves help.
                                #91874
                                  I wouldn't waste your time chaps!
