Hello Alistair,
Have you given much thought yet to what sort of subject would most tickle your fancy? A working ship such as a tug or fishing vessel, or a Napoleonic era ship-of-the-line? A sleek pleasure cruiser or a WWII-era warship? Are you likely to be obsessed with and enjoy spending lots of time on getting every detail right and exactly to scale, or would you prefer the faster-to-the-finish line of a semi-scale approach?
In my mind, none of the above or any of the myriad other ways of building model boats would qualify as better or worse — but I do think that it is important that one tries to understand one's own motivations. One ultimately does a hobby for one's own pleasure, and it is therefore important to choose a project likely to provide exactly that, as this will make one more motivated and … well … better pleased!
That said, one should of course also try to honestly evaluate one's current skills set, and not set the sights so high that the project ends in frustration and is abandoned.
Also try to realistically assess how much time you have to spend over how long a period, and be honest to yourself about how good (or not) you usually are on seeing a long-term project through. Can you see yourself diligently spending on average 10 or more hours a week for two or three years on a single project? If so, the sky (or should that be the ocean?) is more or less the limit! If not, putting a tad more of a lid on your ambitions might get you further — one does not really need yet another bad conscience sitting untouched at the back of a cupboard or at the bottom of the garage, does one?!
Which of a kit or a scratch-from-plans build would turn out the more expensive depends on so many factors that I'd say it is quite difficult to be very definite about that. The clear advantage of a good kit (and there are may good'uns out there!), though, is that it will give you everything in a box (except glues, paints and tools) that you should need to achieve the finished article.
Making a model sail under radio control does of course make things a bit more complicated (it must at least be watertight, and the driveline needs to be installed with some care), but in no way insurmountable. You will need to spend a bit more on r/c and driveline equipment, although these days prices are really quite democratic. For the full lowdown on r/c equipment, including likely costs, I cannot enough recommend the article by forum member Dave Milbourn in the very recent Winter Special issue of Model Boats magazine!
If you want to try your hand at scratch building, one of the free plans from MB magazine might also be an interesting option! These tend to be not too complicated models, and come with an accompanying article to further explain the build and provide many helpful suggestions.
Best of luck and enjoy your model boat building!
/Mattias
Edited By Banjoman on 20/11/2014 14:05:43
Edited By Banjoman on 20/11/2014 14:07:20
Edited By Banjoman on 20/11/2014 14:08:50
Edited By Banjoman on 20/11/2014 14:19:18
