Sorry for the hijack Denis ,this post is mainly for Paul. What Paul means by "too much blue" is because the white LEDs use blue emitters with a phosphorescent coat. Photos under LED lights turn out blue as a digital camera is obviously more sensitive to the narrow blue spectral spike than the human eye.
Paul I was going to say try LEDs but I doubted Denis would go there somehow.
Denis,If you do consider LEDs you will find some really bright ones visible outdoors.
Paul,the LEDs you have use an internal resistor. It is even more energy efficient if you wire up the non-resistor types with 1 red 1 green and then bias the current with a resistor. White LED’s (blue element) require 3.1 – 3.6 volts before they conduct. Three and 5mm types are very static sensitive.
Home LED lighting cheaper to run….yup….. just started replacing all the house lights with LED bulbs. Legislation ought to bring us into line with Australia.
You’ll find the lumileds and their Chinese knock-offs have cracked the colour problem.You can now get 3 and 5 mmm LEDs in a suitable colour temperature too. I bought sample of two downlights to check temperature first When I bought the balance of 15 the rest were bluish
Because I’m a cheapskate I bought 1,500 white LED’s to make up my own 2 watt bulbs with a mix of 16 of 2700K and 32 of 9000K LEDs (K= Kevin colour temperature) .
Off-the-shelf one-watt lamps using twenty individual LEDs don’t have same light as halogen downlights).Those were ideal for public rooms. I’m finishing the job with 3 watt lumileds at £1.60ea and coke can reflectors or colimators. Run at 2 watts they produce same light as 50 watt halogen downlights
Links
shenzhen sheng nan electronics co.,ltd
Maritex for lumiled collimators
Tom
