Robs. I am sure there is NO formula for this. As a forum we cannot decide on ordinary motor combinations !! everyone has their own preference.
However. This is to some degree assisted by your intended battery, as the brushless motors are specified by rev/volt, as well as overall power.
I may have said this before, but you need to decide on prop size, likely revolutions and what sort of battery/voltage you will be using and make some calculations.
THEN look at the power developed by the motor from its specs and decide how much power you need, or can afford from the battery.
Good luck. As it happens I am thinking of putting a brushless in the next project and am struggling with the very same variables…
OR decide what sort of brushed motor you would go for and match the specs to a brushless….?
