hello Mr M see you have dragged me into this topic – as if I need dragging into anything
about using fibre glass resin and tissue, saying I swear by it – I don't know about swear by the method but I have sworn at it a few times – especially when the resin hasn't gone off. & left with a gooey mess to try and clean up
Mick, there is a vast difference between polyester resin and epoxy resin; just to give you a broad outline; polyester resin is very temperamental in many ways and to being with :
- you have to get the mixture between hardener and resin spot on, if you don't add enough hardener the mix sometimes doesn't go off and can stay tacky for weeks on end. If you mix too much hardener in – it can go off rapidly generating great amounts of heat which can sometimes ignite. Or if it doesn't ignite it starts smoking and turns the mixture into a form of cinder toffee which unfortunately you cant eat.
- you have to have a reasonable temperature, no lower than 15 degrees and it has to be a dry area where you are working, this again can upset polyester resin. If the temperature is too low or too damp the resin wont go off.
That's just a couple of the downsides of polyester resin. The good side is its a lot cheaper than epoxy.
Now, for epoxy resins, one of the downsides is you have to be very careful while handling this because some people are very allergic to it, if it gets on the skin – it can cause some nasty rashes. It doesn't smell as strong as polyester resin, but it does have an odour. The good side of it is the mixing – one portion of hardener to an equal amount of resin. That is 1:1 ratio, on the majority of epoxy resins.
The next good thing about epoxy is that its not so temperamental to temperature – it will set at a lower temperature than polyester.
Now, we have been speaking about tissue matts – one has to remember this:
fibre glass tissue matt or heavier gauge matting cannot be used with epoxy resins. This is because the fibre glass matting has a bonding agent, which bonds the strands of glass together in the makeup and this bonding agent dissolves when polyester resin is mixed with it, but, it will not dissolve with epoxy and you just end up with a mess. Make sure you sue the correct materials for the epoxy.
Hope this is of some help.
aye
I am finished editing now by the way
John
Edited By bluebird on 15/09/2014 17:29:05
Edited By bluebird on 15/09/2014 17:29:44
Edited By bluebird on 15/09/2014 17:30:51
Edited By bluebird on 15/09/2014 17:31:31
