water-slide decals
water-slide decals
Home Forums Beginners water-slide decals
  • #30858
    Hugh Mowat
      @hughmowat15664
      Could anyone direct me to a firm who would make me a couple of water-slide decals (or transfers)-not computer-cut vinyl- for my boat names and port of registry?
      height of smallest would be 3 mm, and white lettering is wanted.
      Thanks to anyone who helps!
      Hugh F. Mowat
      Hugh Mowat
        @hughmowat15664
        #30868
        Paul Freshney
          @paulfreshney24971
          Waterslide transfers  can be easily made on a PC.
          Using a specialised paper called ‘Lasertran’, the desired
          transfer can be designed in the computer, printed out using an inkjet printer,
          soaked in water, slid into position on the hull, smoothed out and allowed to
          dry. Once dry, the transfer has to be fixed in position with clear varnish or
          else it will come off when it gets wet.
          Paul Freshney
          Editor.
          #30880
            This is not really relevent, but in my aeromodelling days, I used to make my own transfers, by painting designs onto water based gummed paper with dope.
            Then if a sharp edge was required, the design could be trimmed with scissors
            The paper was soaked in water and the design came away
            Telstar
              @telstar
              hi
              As I mentioned on another thread recently http://www.craftycomputerpaper.co.uk/.-Inkjet-Water-Slide-Decal-Paper_151.htm markets water slide paper and film. I have used this quite sucessfully
              Cheers Tom
              #30948
              Hugh Mowat
                @hughmowat15664
                Thanks to Paul, Bob and Tom!
                I’ve located the local agent for ‘Lasertran’ (I’m in Western Canada) and am investigating further.
                Cheers
                Hugh F. Mowat
                #31488
                paul parkes 2
                  @paulparkes2
                  Hi Hugh
                  Ive just joined the forum
                  I have a custom decal business parkes682decals
                  I make custom decals to order in colour on to clear decal,i also have the world’s only A4
                  “White” inkjet printer so i can print on to clear decal
                  Here’s some aircraft ive done but its “white” on black.
                  The size of the lettering can go down to .5mm (half a millimetre)
                  Edited By paul parkes 2 on 07/08/2011 14:16:09
                  #31500
                  Hugh Mowat
                    @hughmowat15664
                    Paul Parkes
                    Thanks for your response.
                    I’ll get together what it is that I’m looking for and get in touch.
                    Hugh F. Mowat
