Derf. I used a Ford windscreen wiper motor in a fisheries patrol boat for a number of years with no problem. I have seen several posters admit to using something similar in the past, be it windscreen or cooling fan types.
The motors you have tend to be torqy, and not high speed as they are driving a large cooling fan, so would be best for something relatively slow with a largish prop.
HOWEVER…some experimentation might be the order of the day, connecting the motors up to a shaft and run various size props in water to determine the current draw and ability to turn different sized props.
It might be interesting to see your results later on !
