Hi
Anybody out there with a 1-20 tyne class lifeboat 30″ long from old model boat plan .What props suit I am running 2 johnson 600 motors on 6v
Max diameter is 35mm I think.
Also still no feedback on the total weight of the model when correctly ballasted to the waterline as this is a matter of displacement construction method and battery choice should not matter unless this makes the model too heavy before adding any ballast what do you know ?
Regards Graham
