Very warm at the pond Sunday. Park fairly empty, car park remained only 3/4 full.
Good and bad from the Cobb Crusader. Good: the waterproofing measures taken viz silicon around the esc and a plastic bag around the receiver worked well, and after 4 runs during which “an amount” of water was shipped, the boat ran fine. I can’t renemer if I made a larger rudder for it after the last time, or just dropped it down a bit, but the steering was ok…not great, but ok. Having the rudder in the middle is a bit odd and it streets opposite to having the rudder at the stern, however this is easily sorted by reversing the right hand stick.
It makes a sound to die for! The muted jet noise is fantastic, and like the Bluebird, it kicks up spray from the jet pipe just great,
Not so good; it sits very low in the water and when it gets going there is water over the sponson struts, preventing it rising up on the plane. It also makes it very wet hence the water ingress.
The plan is to make some styrofoam ‘shoes’ to fit under the two sponsons, and the front wedge in order to lift it up. The slippers will be a bit wider than the sponsons , the extra width being inboard, and they will be pre-shaped and painted black so I don’t have to re+do the smart paintwork. The bottoms of the sponsons and front wedge were deliberately left unfinished for just such an event.
If I can raise the boat up a bit I am sure it will fly. The original was very wet as well at low speed.
Trevor bought the beginnings of the ‘flying shovel’ down for a peer review and we were impressed, the pivoting “outboard” drive was quite ingenious….(assuming…..)
