  • This topic has 5,252 replies, 84 voices, and was last updated 2 weeks, 5 days ago by ashley needham.
Viewing 25 posts - 4,551 through 4,575 (of 5,253 total)
  • #103191
      There are several ….things…you can make to go with Daleks,as a theme…gosh, even swapping a Barbie for a Cyberman would do.
      Much as like the Mekon, tricky to find more Dan related items to use?. (Answers on a postcard)
      Pond frozen on Wednesday, and the mornings have been even frostier since so I think there maybe too much ice to contemplate icebreaking?
      Terry taking shape. One of the issues was marking out the panels…eight per side…but I think a template will solve that. The light on top is white, not blue as you might think. I will need a small piece of 20mm clear acrylic rod for this. Donations welcome!
        Chaps, I think tomorrow is a no no, the jug of water I keep for my grinder/brush washing has turned into a solid and that’s inside the garage!
        due to warm up a bit by next week——— but don’t hold your breath!
        Ricky ye pirate 🏴‍☠️
        #103208
          Went out to play at a concert last night, 5.45pm, and it took at least 15mins to defrost the car so it was safe to drive. Coming home at 9.30pm, 10 mins wait.
          This morning it looks like the car has been sprayed with white paint.
          No boating methinks. Pond must have 1/2 inch of ice on it and it would take me longer to de-ice the car than the drive to the pond!
          matted clear acrylic squares need gluing into Terry’s window spaces. A tricky feat as if I get glue on the edges I reckon it will show up when they are backlit. Not sure how to proceed. I may smear glue on the frame inner and carefully position the window? Ideally I need a transparent glue in a dispenser with a fine tip to apply a thin bead around the edges. I have some acrylic glue that dries crystal clear and this will wipe off with a damp cloth nicely and may be the way to go.
          As it is, the Matt windows may not provide the right look when on the pond unless the backlight is strong enough to be seen, and I may end up painting the inside of the windows white?
            Mega Deja-vu moment just now.
            Started painting undercoat on Terry’s side panels and thought….hang on, I have painted them already…despite them not looking any different. I distinctly remember doing it…
            THEN I noticed a few light grey marks around the edges and saw that the paint had sunk into the foam. The stuff I ave is dark grey foam and is slightly more porous and less dense than the blue, which means comparing the reverse to the painted there was not much colour difference.
            Just as well I put a second coat on as it should seal it properly now so I should get away with just one coat of blue.
            December mag just popped through the door. A great issue I thought, one of the best….UNTIL Januaries issue!!
            Chris E
              @chrise
              No great Xmas post delay for you then.
              #103227
                Whoops…I meant Januaries mag!
                #103237
                Stephen Garrad
                  @stephengarrad28964
                  Mine arrived today so all's right with the world. (apart from the cold)
                  #103239
                    My brother and his wife are over from Australia for our mums funeral. It was high summer over there, and they come over to minus temperatures!
                    Both have colds.
                      Sorry about your mum.
                      High summer is a bit of an over statement, temps only in the 12/20 C mark.
                      Rain and wind.
                      Australia has cop a lot of bad weather, but Tasmania has miss a lot.
                      #103244
                        Our condolences on behalf of the Forum to Ashley for the loss of his Mum.
                        I met her a few years back when I parked at her place while Ashley and I went up to London togther to do some research at the Maritime Museum plans department at Wookwich. She was a very nice lady.
                        Boiler Bri
                          @boilerbri
                          Hello- I have not posted in a while, but i am still sailing model yachts, after making a JIF i progressed to df65 and DF95's with a hope of getting a IOM- dream on.
                          Hope your all well and I still enjoy reading our posts.
                          Bri
                          #103270
                            Hi Brian. Glad to hear you are still ‘at it’. Not much sailing to be had lately eh!
                            its only -4 here at the moment. The brass band is supposed to be playing carols in Cobham this morning. Madness really but there we are.
                            Not going to be any boating Sunday at this rate. My brother said the locks at Teddington were frozen over yesterday (on the Thames).
                            #103281
                            Dave Reed
                              @davereed72029
                              Shame about the weather and ice on the ponds.
                              Just watched "Bear Island" on TV, the best bits were the airboats on the snow…
                              Apparently it's a Swedish hydrocopter made by Albin and Borje Johansson of Arkosund. If only we had someone known for unusual builds on this forum, we could have all weather sailing couldn't we Ashley……..
                              #103283
                                Well, if you had been keeping up…….yes
                                been there, done that! Ashley
                                Seriously, the issue with skimming on ice is that by the time you get there, the ice is broken up and littered with sticks and stones. We did try the Tups on ice and snow, but the performance was only so so. The craft are very light and flat underneath and tend to just stick to the surface. Given a shove off, they would keep going, but you need a big area to manoeuvre in.
                                Edited By ashley needham on 18/12/2022 09:22:46
                                #103284
                                  The Tup’s we built were supposed to work on snow and ice but in reality snow was too sticky unless it had been frozen overnight and on ice they became a spinning uncontrollable missile! Like the saying, you can’t scale down wind and water or even ice and snow.
                                  #103288
                                  Nigel Northwood
                                    @nigelnorthwood17509
                                    Hoping for a snowy day with a bit of ice to get this project in it's proper environment for some photod
                                    Purchased as a pond yacht in need of tlc, with a weird swing rig, I decided to complete it along the theme of the full size Polar Expedition yachts, like Icebird.fb_img_1641761409217.jpg
                                    #103300
                                      Nigel. I had to wait for snow for both the Zis and Tupolev articles for pictures, not the th Zis actually worked on land or the Tup was whizzy on snow,but the Zis had a winter cameo colour scheme and it was nice to have a bit of context,and the Tups were designed for ice and snow so needed a similar context snap.
                                      Just had a quick preview of Februaries Stingray article. Nice ! Another great layout by Richard. Will be followed a few issues later by a Terror-ble article…..
                                      Speaking of which, Terry Tardis coming together and looking. Rather boxy.
                                        Merry Christmas chaps and chappesseses.
                                        Berengar is working at the Mute Swan pub so only us two at home most of day.
                                        Prezzies when he gets back at about 1700.
                                        Have a super day (off to paint Terries top now)
                                        Ashley. Ho Ho ho
                                        #103328
                                          Merry Christmas from me too. Both Daughters are home so just the four of us over Xmas. Nice and quiet and can relax! Got lots of nice pressies including a 1:1250 Scale Corgi HMS Queen Elizabeth for my miniatures collection. I don't normally collect naval vessels but having seen the carrier several times it makes a nice comparison with my usual liners etc. The photo below was intended to demonstrate to Mrs B my superlative multi tasking abilities but for some reason she doesn't seem convinced….
                                          #103329
                                            i think we are a rather untidy lot, us modellers, as we work in disorganisation, but having looked at your modelling area Colin, that green clutered mat, looks just the same as mine…………..i don't feel so bad now.
                                            Have a lovely festive season everybody and hope you all keep safe and well in 2023.
                                            #103330
                                              It’s cosy. Working at your cutting mat is like building a nest. I find the work area gets more and more cluttered as the build progresses.
                                              Had a look st the QE Corgi carrier and well impressed with it, going to have to get one to go with my collection of Triang minic ships. They are at 1:1200 scale verses the 1:1250 of the QE but near enough. I can escort her with some T45 destroyers, T23 frigates and Trafalgar subs.
                                                As expected, fairly neat and tidy. Luckily my glory hole is in the garage and as my utidyness deeply offends my wife she hardly visits, communication is done by mobile phone and it all seems to work quite nicely.
                                                #103333
                                                  This method usually ensures that your current work is on the top of the pile…
                                                  Re the QE model, I am impressed with it. It comes in a display case and although displayed as a waterline model at sea it is actually a full hull model which is screwed to the bottom of the stand.
                                                  I bought mine at a discount from Antics for £56.75 (Prince of Wales also available)
                                                  It compares very well with the same model from one of the mainstream manufacturers at £189
                                                  Some photos below and in my album here:
                                                  #103334
                                                    In my small corner of the loft conversion where I have my desk,I like to keep my desk tidy and try to put tools away at the end of the day. Also in the workshop in the garden I like to put the tools I have been using away at the end of the day.
                                                    I think it comes from my early working days and training in an analytical lab.
                                                    #103335
                                                      I’m sorry Tim, that’s much too tidy a desk, and I may have to ban you from posting again, as it will make us feel very inferior….although I did notice your small clamps are not all pointing the same way….🤭
