Evening all,
New to the forum – so hi and thanks for letting me join!
K – bit about my background in this area.
Basically, have rebuilt / renovated a couple of old mamods, done a bit of soldering (on the mamod pipework), like to learn and challenge myself on new projects like this.
So…
Bought myself what I think is a scratch built 1/32 PT style boat (on fleaBay).
Unfortunately, I know nowt about RC equipment – but always eager to learn new skills from experts like yourselves!
Will try and post some pics with this thread, but basically I'm wanting to fit full electric RC gear into this model.
She has waterscoop and "outlet", rudder, prop etc – all waiting for the rc gear.
Now – took her to a certain shop specialising in RC gear, to get all the gear I needed.
First thing they tell me, is that the prop shaft is in the wrong place, at the wrong angle – and basically needs the shaft moving and the hull redoing to allow for the move.
Kinda got the idea they couldnt be bothered, but lets see what you guys think…
The prop shaft has a "flexible rubber" section attached to the end, which I believe is supposed to act like a UJ between the motor and the shaft?
Kit I have so far / on order:
1x boat (pics and dims to follow)
1x 8-chann transmitter (presumably ex-rc aircraft)
1x motor with water cooling
(http://www.hobbyking.com/hobbyking/store/__8595__2040SL_4800kv_Brushless_Inrunner_WaterCooled_.html?strSearch=2040)
1 x ESC with water cooling
(http://www.hobbyking.com/hobbyking/store/__24567__HobbyKing_30A_Boat_ESC_3A_UBEC.html?strSearch=30A%20boat)
Basically, the shop I took her to said with the angle of the prop shaft as it is, I wouldnt get a motor in?
I've spent so long "guessing" how / if I can fit the motor (let alone anything else) that I just got some advice on which motor from HK, then will try it and see!
AFAIK, the UJ is meant to allow for any difference "in-line" between the motor and the prop?
So, in addition to the "flexible shaft" on the end of the prop-shaft, I've also ordered a couple of 4mm->3mm UJ's to allow for even more "discrepancy" in the shaft>Motor.
Dont know if I'll need them, but only cost a few £!
QUESTION: Can I mount the motor itself at an angle (to take up more of the angle between the motor and the prop shaft), or should it be mounted horizontally?
QUESTION: Quite like the idea of a small gearbox between the motor and the shaft – to both take up the angle and increase speed / reduce torque on the motor. Good idea?
QUESTION: The motor as above has the water cooled jacket, with I believe 4mm barbs on to connect the hose (which im assuming is like aquarium air hose, which I have).
The scoop / outlet already on the boat look a bit like these…
http://www.modelshopleeds.co.uk/catalog/popup_image.php?pID=7245
Unlike these however, the outlet on mine looks more like the fixing on the back of the scoop shown – looks like 6mm bore with thread on the outside?How does one attach the hose to them?
So, apologies for all the dumb "noob" questions – I've spent so long "thinking about" this project, I think it's best to make a start (hence the motor) and see what I can work out from there.
Any help or advice much appreciated!
(If you need any more info, dims, pics etc to be able to advise, please let me know and I'll post).
Pics (These are shared from my G+ album, not sure if you'll be able to see them – will work out something else if not).
https://plus.google.com/116563859822186576309/posts/TMLByumo6Lr?pid=6047880751969958450&oid=116563859822186576309
https://plus.google.com/116563859822186576309/posts/TMLByumo6Lr?pid=6047880752203589122&oid=116563859822186576309
https://plus.google.com/116563859822186576309/posts/TMLByumo6Lr?pid=6047880753105534994&oid=116563859822186576309
https://plus.google.com/116563859822186576309/posts/TMLByumo6Lr?pid=6047880753419072002&oid=116563859822186576309
https://plus.google.com/116563859822186576309/posts/TMLByumo6Lr?pid=6047880752236817378&oid=116563859822186576309
