Thames Sailing Barge Stuff
Viewing 25 posts - 176 through 200 (of 782 total)
  • #79321
    Andrew B 1
      @andrewb1
      Hi the two vangs ( wangs ) on a full size barge control the 4th corner of the sail, and the sheet end of the tops'l by acting on the outer end of the sprit. The 2 wires have a tackle at the bottom, which comes to the deck very near the main horse.
      In a model barge, if you put a functional block at the outer end of the spreet you can replace the 2 vangs with one continuous string, and you only need one servo. Make fast on deck just forward of main sheet horse, run up to end of sprit, through block and down to corresponding position on the other side, i,e just forward of horse, where is goes down below decks and to the servo with a simple arm to sheet in/out as required, in line with main sheet position on another servo.
      I would reccomend 'Sailing a Thames Barge Sail by Sail' very cheap, from TBSC sales officer.
      Andrew B 1
        @andrewb1
        I would also sign on to Facebook and join the group….model thames sailing barges
        #79325
          Hi Simon,
          My TID tug with a 400 brushed motor & 35mm 3 blade prop on 6v moves Veronica at a fair pace regards Rayb&a tug aug 16 004.jpg
          #79326
          Simon Harlett 1
            @simonharlett1
            many thanks Andrew for the speedy response. I have joined the Facebook group which looks extremely useful. I may ask for a diagram of vang and mainsail rigging to servo at some point as I’m still learning the lingo with regards to the different term used.
            #79327
            Simon Harlett 1
              @simonharlett1
              Ray, if a 400 motor pulls a Veronica, then that’s the way I will go! Certainly a lot cheaper than an 800!
              #79362
                Veronica's in drydock for winter repairs & maintenance, going to be faster next year, new topsail on the agenda
                #79363
                nick viner
                  @nickviner52422
                  What a lovely looking model,
                  Cheers Nick.
                  #79365
                    Yes she is, I take no credit for her build, Peter Simmonds of the Isle of White built her I have added new sails and a grp winged keel to make her more competitive as good as any on the day, I'm owner/caretaker/skipper
                      Hello Ray
                      Nice pretty picture of your barge being towed
                      But………Would a barge be towed under full sail?
                      Just nit pickin'
                      nick viner
                        @nickviner52422
                        It would if it was clearing harbour.
                        #79369
                          Hi Bob,
                          I'm sure the mainsail brail ropes would have the sail pulled into the mast in real life there was no wind that morning, I think the crew were still asleep !
                          Eddie Lancaster
                            @eddielancaster
                            Hi. All, a bit more progress on my TSB Veronica,
                            The hull is almost finished,as you can see it is painted and some fittings added.
                            The hatch tops need to be fitted and then covered with cloth and the battens and hooks with the wedges.
                            The main hatch holds all the servos. The servos are all on boards that are screwed to supports so that they can be removed if/ when anything goes wrong.
                            The rudder servo is under the back cabin. All the cords and sheets are in, all as suggested after my last post, I just need to fit an arm to the servo that controls the vangs.
                            Eddie.
                            #79486
                              Hi Eddie,
                              Your building at quite a pace!! well done all looks good I've started started drafting a Giralda at 1/24th scale for traditional plywood build and toying with the idea of a super lightweight version Epoxy/glass sandwich, It used to work for racing dinghies why not a barge??
                              All the best Ray
                              #79487
                              Eddie Lancaster
                                @eddielancaster
                                Hi. Ray, thank you for your kind comments, that is the easier bit out of the way, but now on to the rigging and sailsfrown, but now that I have something tangible I can relate the information that I have to what I have in front of me.
                                I will be interested to see what you come up with on your next build.
                                Best regards.
                                Eddie.
                                #79503
                                  Hi Eddie,
                                  I couldn't recall if you have made your sails yet? but big discussion on sunday morning about the virtues of Wonder Webb as sold in needlework shops for hemming , here is the go-faster main for Veronica
                                  #79508
                                  Eddie Lancaster
                                    @eddielancaster
                                    Hi. Ray, yes the sails are made, all with sewn hems and bolt ropes sewn on and hooks, eyes and cringles to fix them to the jackstays, forestay and sprit.
                                    What is different about your go faster sail, is it just larger or made from a different material? or is that top secret at the moment! It looks good on what I assume is the kitchen work top. I will check out that Wonder Webb next time i'm in town.
                                    Regards.
                                    Eddie
                                    #79518
                                      Hi Eddie,
                                      No magic just a better fit right down to the hatch cover to stop the wind escaping, you are well on if you have finished your sails, when you get her finished I'll come up and give you a race, or if your down at Broadstairs you could come to an AMBO race at Herne Bay ?
                                      Eddie Lancaster
                                        @eddielancaster
                                        Hi. Ray, I'm pleased that your new sail will be down to the hatch as mine already does that, I thought I would have to remake it, but perhaps not now.
                                        I have already spoken to my friends about meeting them at Bluewater when you are there and going to Herne Bay when AMBO have a race theresmiley.
                                        Regards Eddie.
                                        #79540
                                        tomarack
                                          @tomarack
                                          Hi gents,
                                          very nice models , indeed!
                                          Now I'm making triple stayfall tackle , to be able to continue with the rigging for my Gusty Cat .
                                          I can reccommend next pages > http://www.boat-building.org/learn-skills/index.php/en/wood/making-blocks/
                                          > there are next interesting articles.
                                          Greetings
                                          Tom
                                          Edited By tomarack on 27/10/2018 21:53:28
                                          #79549
                                          Eddie Lancaster
                                            @eddielancaster
                                            Hi. Tom, nice to hear from you again, I have just started to rig the main mast on my Veronica, what fun! I will post some photos when its done.
                                            All the best.
                                            Eddie
                                            #79557
                                            tomarack
                                              @tomarack
                                              ..Hi Eddie,
                                              I have the main mast almost ready to install too ,as I wrote, there is no stayfall tackle. I have to shape the parts of the tackle, and put it together – a few more hours of work before me . Parts of .blocks are made of brass the same way I made these for Capricorn . Sorely no new photos at present ..
                                              All the best
                                              Tom
                                              Edited By tomarack on 28/10/2018 16:34:29
                                              #79600
                                                Hi Eddie,
                                                Here is a snap of Veronica's shrouds and backstay location, keep us posted with your rigging
                                                #79601
                                                Eddie Lancaster
                                                  @eddielancaster
                                                  Thanks once again Ray, your rigging is all in front of the leaboard roller, I will do the same, on the drawing the topmast running backstay is located behind the leaboard roller about 130mm further back.
                                                  The masts are quite firm even without the backstays so they only need to take the pressure of the sails and to hold the forestays firm.
                                                  I have tried the mainsail in the wind today and all seems to be fine,with good control from the winch, I think I can also control the vangs from the same winch as suggested some time ago, so reducing the number of channels and servos needed.
                                                  As soon as I have tied up the last few ends, ( pun intended) I will post the results of my efforts.
                                                  Regards Eddie.
                                                  #79602
                                                  Martin Field 1
                                                    @martinfield1
                                                    Gents, I have been asked to make a master pattern for a cast resin 4mm -1 ft. scale TSB. Knowing very little about them I am asking your help. Which type/actual barge would be a good choice? The guy is leaving it up to me to choose and whilst I am au fait with different types of TSB, I am not so clued up on which would likely be the best one to depict as a scenic accessory for model railways which is where this one is intended to go.
                                                    Thanks in advance,
                                                    Martin
                                                    #79603
                                                    Andrew B 1
                                                      @andrewb1
                                                      Eddie/Ray,
                                                      On a full size barge, the backstay aft of the leeboard roller is the Topmast Running Backstay, and supports the top of the top mast preventing the mast from bending too far forwards due to the pressure ( on a stays'l ) barge from the Stays'l. The real life crew have to let them off and do them up again whenever the barge tacks, and certainly of the they want to put the mains'l in the running position, otherwise the weight of the sail or sprit on the backstay will snap the topmast backwards….this is the reason they are not modelled on a functional sailing model.
                                                      As I think I've mentioned before my vangs are on the one servo, and I've just tested my leeboards – out of the water only, which are on another servo positioned with a wooden servo right across the bows in the void space I have there, I have a 3 position switch on my Tx which if you think about it is perfect, (Port one up and Stbd one down), (both in a mid semi dropped position), (Port one down and Stbd up )
