Thames Sailing Barge Stuff
Viewing 25 posts - 351 through 375 (of 782 total)
  • #82501
      Hi Dave,
      My next match will be Silvermere, rumours are Maldon water level very low, check before you go, it's a lovely place but a blooming long way from the IOW, and relatively small lake.
      Dave Sansom
        @davesansom26019
        Hi Ray
        Thanks for update on level, will let Peter know, don't think we will be going, see you at Silvermere.
        Take care Dave (IOW)
        #82507
        Andy Stoneman
          @andystoneman15177
          Hi Dave,
          Its well worth the trip to Maldon, we came from Australia to see it. Nice lot of TSB's the to look at !
          Andy
          #82511
            Hi Andy,
            What are you building at the moment ? I guess as we are approaching summer it must be snowing about now for you ? 😀 we are off to Malaga next week for some proper sun.
            All the best from the UK
            Ray
            #82512
            Dave Sansom
              @davesansom26019
              Hi Andy
              Peter Simmonds did tell me later that it may still be worth a visit.
              That's after I'd told the good lady I wasn't going.
              So will be playing it by ear .
              Thanks for letting me know
              Regards Dave (IOW )
              #82518
              Dave Sansom
                @davesansom26019
                20190508_185525.jpgHi Ray
                Thanks for head up about the lake
                Going to Midhurst show instead.
                Photo shows start of project
                Should be finished about 2021 LOL
                #82535
                Andy Stoneman
                  @andystoneman15177
                  Hi Ray,
                  I am building and have almost completed, apart from sea trials, the Nixie Submarine, A bit wary about sailing it, water is a bit too cold for a dip if things get out of hand, I don't fancy a murky pond this time of year and the big pond at 22c still too cold. Hope your weather is much better.
                  Andy
                  #82536
                    Hi Andy,
                    Lots of excitement here 35 Dakota's are flying from Duxford via Maidstone to the DDay beaches on wednesday should be quite a sight 😀 I seem to do steam engines in the autumn, rather weird ?
                      @timrowe83142
                      Hi Ray
                      You should be packing not posting wink
                      Tim R
                      #82539
                        Thanks Tim,
                        My better half has nearly filled both cases !! With her dresses I thought I was due to be going along as Well ??
                        Andy Stoneman
                          @andystoneman15177
                          Hi Ray
                          You know your on the list to go mate, who will carry all the luggage else ? Have fun !
                          Andy
                          #82640
                          Eddie Lancaster
                            @eddielancaster
                            Hi. All have now fitted new sails and a sail arm servo to my Veronica TSB the peak of the sprit has been lifted by about 4" and is now 24" above the deck, the sails then had to be re-made using Dunelm's best poly cotton bed sheet in Terracotta and a lot lighter than the original sails.
                            I originally fitted a sail winch with a continuous line running through a tube around the stern under the deck,the sheets for the vangs and mainsail were then fastened to either side of this line and inline with it,but if the sails didn't pull the sheets out they would tangle and pull the line of the winch drum.
                            Sailing today she handled much better and was faster, at times keeping up with a Marblehead yacht, but wouldn't point into the wind as well, and she didn't heel as much.
                            Regards.
                            Eddie.
                            #82642
                            Dave Sansom
                              @davesansom26019
                              Thanks Eddie
                              Now I know where to get sail material
                              Dunelm 😀
                              #82644
                              Eddie Lancaster
                                @eddielancaster
                                Pleased to be of servicesmiley.
                                Eddie.
                                #82658
                                tomarack
                                  @tomarack
                                  Hi,
                                  here is foto Peter Simmond´s Veronica, the double sheet.. for Mainsail,single sheet for Vangs100_2265.jpg
                                  Edited By tomarack on 17/06/2019 20:03:42
                                  Edited By tomarack on 17/06/2019 20:30:59
                                  #82660
                                    My little 30" Gertrude has a single standard servo with an arm, giving direct control to both the main sheet and vang seems to work ok, most racing is won or lost close hauled beating to windward 😃
                                    #82661
                                    Eddie Lancaster
                                      @eddielancaster
                                      It's good to see the internals of other boats to see the different solutions to the same problem.
                                      Eddie.
                                      #82901
                                      tomarack
                                        @tomarack
                                        img_1712.jpgimg_1711.jpgHi,
                                        Yesterday I put Gusty Cat for the first time on the water. After about 5 minutes the servo rudder stuck. I was glad to get the model to shore. It seems to me that even with a small staysail the model will run well.I have to replace the servo and then try the model again. Unfortunately, I was not able to take a picture of the model during the very short cruiseimg_1709.jpg
                                        #82902
                                          Hello Tom,
                                          Good to see her on the water where she belongs, the servo will be an easy fix, glad to see you have good weather at last ! And your dog can take you for a walk 😀
                                          Eddie and I are going to build Destroyers next, we should have a small navy soon 😮
                                          Kind wishes from the uk
                                          Ray
                                          #82903
                                          Eddie Lancaster
                                            @eddielancaster
                                            Hi.Tom, nice to see her on the water and with some sunshine, look forward to seeing her under sail soon.
                                            Regards.
                                            Eddie.
                                            #82920
                                            tomarack
                                              @tomarack
                                              Hi gents,
                                              mea culpa, mea culpa .. today I tried to turn on the GK receiver again, nothing worked. Finally, I found that the battery had a low voltage, about 9.5V.Then I could be surprised that nothing works…
                                              If it comes out tomorrow, I'll go back to the park with the model. For a change … I hope at least a little wind will blow……when model seems to be ok…
                                              Lately I have problems signing up here at MB. Yesterday I entered a new password three times, and today again .
                                              greetings
                                              Tom
                                              #82924
                                              Eddie Lancaster
                                                @eddielancaster
                                                Hi. Tom, yes you do need a few of those volts to make things work, not sure about the MB site, it seems to be working here.
                                                Regards.
                                                Eddie.
                                                #82932
                                                tomarack
                                                  @tomarack
                                                  img_1723.jpgHi Eddie,
                                                  next troubles with password now.
                                                  So … I found out that the servo was probably OK, the problem was caused by a discharged battery. I recharged the battery and took the spare battery with me. Everything was OK. I loaded the model + accessories onto the cart and brought them all to the park to the pond.The weather didn't feel very good to me, it was quite cold by the water,
                                                  and the wind almost did not blow. The model behaved unexpectedly well on the water, so I could make some photos.
                                                  Next time I need to fix the clutch on the auxiliary engine and I would like to install a mini voltmeter to monitor the battery voltage. It would make my control much easier.
                                                  Next photos are in the album (Gusty Cat)
                                                  Edited By tomarack on 10/07/2019 17:59:26
                                                  #82936
                                                  Eddie Lancaster
                                                    @eddielancaster
                                                    Hi. Tom,pleased to hear that you are slowly eliminating your problems, as you say not enough wind to fill the sails.
                                                    Perhaps another day though.
                                                    Charging my batteries at the moment ready for tomorrow, but rain is forecast, Susie May only uses about 250 milli amps over a 3 hour sail time.
                                                    Eddie.
                                                    #83667
                                                    Eddie Lancaster
                                                      @eddielancaster
                                                      30" TSBs at hearne Bay today.
                                                      Hi.Ray, I had a great day meeting you all and seeing your boats, and recieving your help and sugestions to improve the sailing of my boat
                                                      As soon as I get home I will start work on it and hope to have them all completed for the Bluewater Meet.
                                                      All the best.
                                                      Eddie.
