Some more from that Manx Bargee!
Hello Bob, some technical stuff, but simple.
The keel weights as used by me, the red heavier one (on a longer fin for deeper water) used in strong winds is a Marblehead lead at 3.6Kg. The blue lighter one is, by looking at it, about 1/4 of a IOM lead (2.4Kg) which probably makes it only 1 1/2 lb max. [I'll go up in the attic and weigh it soonest.]
Here's the barge with the red keel on and in "coastal trim" (no bow sprit.) The two keels are below too.
Now I've also added a picture of the rudder extensions used. I mentioned this before. As we sail empty barges there is very little water grip of the rudder when sailing. It is possible to motor without the extension. Rudders from my two barges, note different styles.
You've been on the AMBO website, so know we've have several build guides and have had discussion also about where the keel/fin needs siting and even does a model barge actually need one. All good stuff.
I'll try and get some engine layout and shaft alignments copied for you on the next posting, Kim.
