Hi All
I can vouch also for the 3639-1100 kv motor with the 60am car controller from Hobbyking, however as I have said previously Hobbyking just doesnt seem to work for me.
I should state I am more of an model aircraft builder of some 35+ years than boats, I started in electric flight back in early 80s but believe my skills learnt in this can be transfereable to boats. I try to build lightness in any structure and to strengthen where necessary, whereas if built heavy it is really difficult to lose weight. Of course there are very many people on here who have vastly more experience than me, I just look at the quality of the builds on this forum and am totally spellbound and amazed by it and am enjoying learning from my peers.
Tony try the 500 on 6 cells first, then try 7 and then 8. If you find thats not working for you and you want a straight swap buy a graupner speed 600 8.4v, there are various sources for them and range in price from £7.00 upwards. I believe they are same diameter and very similar in length. Not sure about diameter of the shaft though so you may need to change part of your coupling. The good thing about this motor is you can remove the flux ring (which is a metal band surrounding the motor) and it spins faster, however doing this also increases current use therefore reducing your run time. I wont go into how you can tune brushed motors as too complex here. One thing I learnt from electric flight using brushed motors is that motors spin faster and are more efficient in one direction than the other as they are timed to do so, look at the instructions you have with the motor to tell you which way that is and obviously fit the right prop for either right hand or left hand rotation.
In regards to props, has anyone shown you the correct way these should be fitted to the propshaft? I wasnt shown and kept losing props. My current understanding is at the prop end you fit the washer first, then the nut and then the prop. Screw the prop home and then tighten the nut against the prop to lock it. The shaft should be free floating at other end with no nut and ideally you need to have minimal end float on the shaft at prop end. To tighten or loosen end float move shaft in or out of coupling. You also need to lubricate the shaft and this alone has good debate here on the best way to do it
Dont worry about the deviation I,m pretty sure it will be fine, even if it pulls slightly to one side correct with rudder. One for future thought if using ply, which you might not have tried is to try soaking it in the bath/sink for a hour or so prior to putting on model, secondly you might want to fit opposing parts at same time such as sides and letting them dry together which alleviates stresses and hopefully any warps or deviations. Also stringers I dont tend to use 6mm I use 2 x 3mm as the 3mm is easier to bend and stay in place, alternativley steam the 6mm to shape prior to fitting.
To be honest I have never weighed the models but can tell there is an appreciable difference between all three.
One thing you may want to think about and I havent seen it mentioned here is to put some floatation material or foam in just in case boat overturns. I use EPE foam pool noodles which are lightweight and can be cut down and put in various areas. I dont tend to stick them in other than a very small dab of silicone to hold in place.
Harry thanks for the advice re the speed controller,Ill give it a try interestingly Im just about to start on a sea commander. I have the plans and this weekend will cut all formers etc. As I have a batch of marine ply in 3mm and 4 mm a majority will be cut from this, I intend to skin the outside with 1.5mm beech ply, then epoxy coat the lot and paint on top.
All the best Andy
