(Following a request from Paul T on Bob Abell's thread on his version of Ellie, I have put this together for those who feel they might need more information. Frankly I think it's just Paul winding me up again, but there you go………)
This is not the easiest subject to explain and I would question whether most modellers really need to know at all! There are probably hundreds of different websites which all do it better than I can, but here goes anyway:
Capacitors have two internal plates which are separated by a non-conductive material called a dielectric. If you connect them up to a DC supply then these plates become quickly charged up (one positive and the other negative) to the same voltage as the supply BUT because the plates are insulated from each other they will not allow a direct current to flow between them. This is why you can fit one across a DC supply without it short-circuiting the whole issue.
A DC motor not only spins when you apply a voltage across the brushes but also acts as a voltage generator of what is know as back electro motive force ( or “Back EMF" ) when it is rotating. This e.m.f. alternates in polarity as the commutator of the motor rotates and the brushes act as on/off switches to the generated current. This will produce unwanted transient voltage spikes superimposed onto the speed controller/battery circuit and also quite possibly will generate electrical sparks at the brushes. These sparks are like the old-fashioned crystal radio sets i.e. they result in the transmission of a spurious high-frequency radio signal (RF).
Both the voltage spikes and the RF interference will adversely affect any connected electronic circuits. A capacitor will allow alternating current to flow between its plates because they alternately charge up and discharge with the changing polarity of the supply. This means that you can ‘dump’ an unwanted flow of alternating current to ground (usually the motor case) via the capacitors connected to the brushes and smooth out the unwanted ripples in the motor supply caused by the voltage spikes via the one across the two brushes.
The values aren’t critical so 0.1uF – 0.22uF is generally used for the latter while the ‘dumping’ suppressors between the brushes and the motor case can be as little as 0.01uF. Ceramic disc types are the best (and cheapest) as they can withstand the higher voltages, but you should avoid electrolytic types as they are polarity-sensitive and will go bang as soon as you reverse the direction of the motors. You wouldn’t believe how much insulating tissue wadding could fit inside such a tiny can………..
OK – it's now open-season for all tecchies to shoot me down in flames! Just remember that I was pushed……
Edited By Dave Milbourn on 28/11/2013 17:38:24
