Hi Bob
The easiest way to answer your points is to do another Q & A so here we go.
If the sponsons are buoyant……It doesn`t matter where they are on the surface
The sponsons buoyancy isn't part of the equation as they remain below the surface at all times.
The model can go fast or slow at any time
Yes but the position (angle) of the wings have a direct effect on the forward speed (see below)
I have been assuming that the wing motion is powered btw!
On the real boat I believe the wings are computer controlled and operated by hydraulics…the computer control is linked to the forward motion of the craft.
Don`t understand your idea of wing position being important to surface speed?
As the wings come together they create a ground effect area which allows the craft to travel faster, in effect the wings trap a 'box' of air between the water surface and the underside of the superstructure and the craft rides on this box of air (much like a hovercraft) which permits higher speeds to be achieved.
The angle of the wings also has a direct effect on the efficiency of the cavitation system.
I hope this helps explain why the link between forward motion and wing angle is so important.
