Super cavitating very high speed stealth surface vessel
Home Forums Scratch build Super cavitating very high speed stealth surface vessel
Viewing 25 posts - 51 through 75 (of 328 total)
  • #54872
      We need to exploit the artist`s licence for my suggestions to work!
      Chunky pivot area, as large as the motors, to house the pulleys, with boxy legs to house the Brushless motors and batteries
      We can`t make a scale model, but we can adopt the features of pivoting legs, contra props and space age shape
      The pivot mechanism could be a screw thread driving a rotating nut on an arm with about 45 degrees of movement
      Say a 40" hull with a hull 12" wide x 8" deep
      10" radius legs with the sponsons….4" dia x 30" long
      One normal propshaft inside a tube with a second prop fixed to the tube
      One pulley for the propshaft and one for the tube
      This would be my starting spec
      Any good?
      With the space age Brutus style, it may look ok?
      Just thinking out loud and can`t really get down to the nitty gritty till the VGC is finished, but once we agree on the design, I`ll work with you
        Back to the design work
        One of the things that have to be identified are structural changes that have taken place over the life of the boat. For example on the Ghost boat a couple of changes jump straight out.
        The addition of cowls to the cooling inlets (Red) and the new stubby wings (Yellow)
        The images on the left show the boat in its original condition and the images on the right show the additions.
        The cowls and wings are very obvious changes (but how many of you spotted them……be honest) but there are other far more subtle alterations that have been made.
        When working on a design for a model of an existing boat it is important to identify which period of the boats life you wish to concentrate on and then include, or exclude, the relevant components.
        As Bob is the 'client' it will be his choice as to which version we build………although based upon recent experience this simple decision is likely to be fraught with many complications: lol
          Its Question and answer time again wink
          The original instruction was for a scale model so artistic licence is out.
          See the above answer
          We can make a scale model using the design features that I have already worked out, the model will perform exactly as its full size parent. We cant make a scale model using the design constraints that you seem hell bent on using.
          This is a good idea and might be better than my plan to use twin heavy duty servos
          Thank you for the dimension request unfortunately due to the constraints of scale we can only adopt one of your proposed dimensions…….I would suggest that we explore the 40" as an overall length and see how the rest of the model scales to this length.
          10" radius legs with the sponsons….4" dia x 30" long.
          If we are working to an overall length of 40" then these dimensions will become evident as the 'scale' model is drawn up and detailed.
          This is another good idea and might prove more cost effective than my gearbox proposal
          As above
          A specification……..be careful Bob or people will think you know what you are doing
          Any good?
          Some of this is good and some is just 'pie in the sky' as you are fond of saying
          The parent boat does have a unique style and is proving to be a challenging subject
          I like your thinking aloud even if it is done in crayon laugh
          #54875
            I didn`t think you had started the design work……How far have you got?
            Your design is based on motors and batteries inside the sponsons
            How do you propose to have a reliable easy sealable opening for access to the stuff inside?
              Hi Bob
              Ever since I first looked at the boat I had envisaged using plumbing plastic drain pipe and fittings for building the sponsons, this type of pipework comes in various diameters and have a mixture of welded joints and best of all rubber sealed threaded fittings.
                Back to the design process.
                There are a few different ways of getting the information necessary for producing drawings.
                The best and most accurate method is to find templates or blueprints of the subject and I always visit The Blueprints.com **LINK** to see if they have a set of blueprints that I can use.
                But for most of my design work I end up tracing images from photographs although it should be mentioned that the photographs must be 'square on' so that details aren't lost in the perspective.
                For example these images are suitable for tracing some details of the front and side elevations
                The tracings don't have to be super neat as they will be straightened up as the design is worked up. To get sufficient information for the entire boat you might need to copy a few photographs and be inventive in the places that aren't covered by photos. I know it sounds complicated but the eventual results are 95% accurate.
                NB
                Whilst I have done this on a computer the same work can be done with a photocopier or scanner and home printer (it takes longer but it can be done)
                The next stage is to overlay and compare all of the tracings to ensure all of the components are picked up and then begin to work up the sketches into working drawings, even with a computer this part of the process can take some time.
                Edited By Paul T on 05/01/2015 18:21:06
                #54884
                  You`ve copied that well!
                  From your earlier posting, the sponsons look about 50% longer that the hull and tapered at both ends
                  Can`t see us doing that with a plastic drain pipe
                  A scale model looks like a bridge too far………Prefer a simplified semi scale version….Said the Client
                    Questions and answers
                    I was trying to show that the tracing doesn't have to be perfect but all will become clear when the drawings are produced
                    Yes that's about right
                    Maybe you cant ….but I can and I can show you how to do it
                    I didn't expect you to give up at the first stage. But don't worry, if I cant design it you won't have to build it.
                      How can the sponsons stay submerged at speed?
                      They either float or they don't?
                        We could make the sponsons from drain pipe material with solid wood tapered ends
                        We could flood the sponsons if required
                        Have the motors in the hull, but fit the props below the hull, level with the lowered position of the sponsons on a support with a pair of rudders. They wouldn't be seen and makes life easy
                        Any good?
                        With widespread wings, can't see it being unstable
                        I can see motors in the sponsons, easily enough, but the batteries in the hull for accessibility
                        Edited By Bob Abell on 05/01/2015 21:15:07
                        #54891
                        Andy C
                          @andyc56856
                          I do love a good mystery. Also been interwebbing super cavitation, very interesting topic. Looking around though it is not the motors wot make it fast but the way the thing sits in its bubble. So a very normal brushed motor sitting in the sponsons with the correct cavitation forming nose cone should work. Servo powered hinges connecting the "wings" to the hull, to stop them moving too much and Bob's your aunties uncle, there you have it. If the Russians could do it in the 60's we must be able to come up with something nowadays.
                          Back to the shadows again. My man cave now even has wifi.
                          Andy
                          #54892
                            Hello Handy Andy…..Your excelling yourself tonight?
                            It's encouraging to hear your positive comments
                            I'm tempted to abandon the pivoting wings, but they are an essential desirabell feature and will be great fun to play with on the water
                            Call again
                              Paul…..Can we make use of the magic words….Super cavitation?
                              I would have thought that super cavitation would be inefficient?……Normally, cavitation is to be avoided?
                              Is the propellor belting round in fresh air?
                              Paul is in his Bat cave at the moment, how he gets to sleep, hanging upside down, I've no idea?
                              If we use brushless motors, we could use those super lightweight batteries in the hull?
                                I am looking at the super cavitation system at the moment but no the props don't run in fresh air.
                                Super cavitation is very effective: the company that built Ghost (Juliet Marine Systems) is claiming very high levels of efficiency but, as yet, I haven't found any independent data to support their claims.
                                For the sake of avoiding any further misunderstandings it is highly unlikely that any equipment other than the receiver will be located in the cabin (hull)
                                Here are some preliminary dimensions for you to consider:
                                The overall length is 1200mm, the sponsons are 55mm dia, the cabin is 800mm long by 180mm high and the wings are approx.170mm long.
                                  Keep up the good work, Paul, but don't overdo ithings
                                  You've left me miles behind on this job
                                  Hope it all works out for us……It will be a spectacular model for the Haydock show!
                                    This is the tidied up side elevation
                                    So now you can see how the overall model would look.
                                      Looking good, so far, Paul
                                      What about the props?
                                      Where would the waterline be in this view?
                                        I am still looking into props so I've not included them on the drawing.
                                        The waterline is just above the sponsons.
                                        What size brushless motors do you have in stock? (for fitting into the sponsons)
                                          Got 4 x Turnigy D3536/6 1250 KV….1250 revs per volt
                                          Body 35 dia x 40 long plus shaft 5mm x 16 long
                                          They don`t look big enough
                                          How will you keep them dry?
                                          Andy C
                                            @andyc56856
                                            Don't need to keep brushless dry. Found a few vids a while back where peeps were running them in water with no ill effect.
                                            https://www.youtube.com/watch?v=ejRRek-4tL8
                                            Edited By Andy C on 06/01/2015 23:24:22
                                            #54919
                                            Andy C
                                              @andyc56856
                                              Sorry, you have got to see this one. Won't spoil the surprise.
                                                Hello Andy C
                                                Thank you very much for such valuable information!
                                                It could be the answer to a very difficult problem……Sealing the motors!
                                                It certainly has made the job easier
                                                The super cavitation video is also very interesting, but I don't think we cam go fast enough, for the phenomenon to come into action……Will read it again
                                                Paul will be very impressed
                                                Thank you very much for the info
                                                  Andy
                                                  Thanks for the links and for offering advice as both are really appreciated. I had an idea that these brushless thingies can run underwater but I wasn't sure……….and having see it happen I'm still not sure as it goes against every engineering principal that I know. I just goes to show that you are never to old to learn something new.
                                                  We don't have to seal the motors…just the prop shafts where they pierce the hull (exactly like any other boat)
                                                  The model is theoretically capable of achieving very high speeds especially if we can get the legs to work correctly so the cavitation system is a distinct possibility.
                                                    Is that a typo?…..Where the prop shafts pierce the hull?
                                                    If our brushless motors are too small, why not make the model size suit the motors?
                                                      Good Afternoon Bob
                                                      No it isn't a typo: The propshafts pierce the hull of the sponsons at the front (where the props are)
                                                      But before Kevin starts to get confused with the names of the major component parts I think that we should stick to the following descriptions.
                                                      Re brushless motors and the size of the model……………..someone, I cant remember who, requested that the model be about 44in long and so the design is being done to suit this request.
                                                      Kevin
                                                      You might find it easier to think of this project as a cutting edge catamaran rather than a futuristic stealth boat
                                                      Off for a cream cake and a coffee.tea
                                                      Edited By Paul T on 07/01/2015 15:25:22
