Hi Mick…
Thanks for the offer of the plan, would be good to see how the pro,s do the plates.
The template I used for the test run was card…card…lol
The only white card I could get from the news agent, was 180gm..
I cant find the thread that Bob posted on how thick the card was he used..!
>>I have made working scupper flaps have cut them from ally and bent them need to fit <<
I hope you can post a picture when you have installed them.
I will have to go back to the news agent and check out the model boat mags.
You got the colours, you wanted ?
>> did you grind the punch to a rounded end and what sort of spacing did you use? it looks like around a 1/4" or 3/16ths"<<
I have just made an A4 template to have a go..
Sent a message to Yabbie1, he is very kindly requesting more info from the Wattle referb chaps and will get back to use as and when…
But you are so right…the punch is to big for the cabin area and probably the funnel.
as for the scale size of the plate and rivet spacing…hope to hear from John, when he has the time.
